Author Topic: Searched the fourms/Faqs and no luck-  (Read 2424 times)
Kane
  • Last login:June 06, 2023, 08:05:47 am
  • What?
« on: March 04, 2003, 08:31:57 am »
I am looking for some kind of write-up on how to install a Happs trackball. My cp is 3/4 inch wood and I need some help as I've never done this. I have found some pics but it seems that every site that discusses building a cab./cp skips the process of mounting the trackball. :( Any help much appreciated.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Searched the fourms/Faqs and no luck-
« Reply #1 on: March 04, 2003, 09:38:04 am »
bah.. hold on this was just discussed last week (and the week before)
*grumble rummage grumble*
rampy
EDIT how about here?
Basically you use the mounting plate (you did buy a mounting plate, right), although eightbit and few others got by without a mounting plate, but mounting plate makes it straightforward how to proceed.
Basically you cut the football shape out of your panel, drill holes for the outer mounting plate bolts/posts.  you use the inner bolts/posts to connect the mounting plate to the trackball, then slide in the whole assembly and fasten the mounting plate to the control panel. (of course I assume you have some way of wiring the trackball up) That's the basic gist.  If you look at a mounting plate, your trackball, and your control panel it should make sense, but skim those previous threads for interesting info like trackball orientation and flush mounting tips.
Rampy
EDIT2: PS HEY! wait a minute... YOU started the previous thread. arg!
« Last Edit: March 04, 2003, 09:48:29 am by rampy »
Kane
  • What?
« Reply #2 on: March 04, 2003, 09:52:54 am »
Doh! I need to slow down and learn to "read" not skim. I did not get a mounting plate (I purchased off of ebay for great price) Sorry to waste time going over the same things but I want to do this right :)
rampy
  • *shrug*
« Reply #3 on: March 04, 2003, 09:56:18 am »
You can do what ever you want (regarding the trackball mounting) but I suggest getting a mounting plate.  I belive bob roberts has them if you wanted to avoid the dreaded 25 dollar minimum at happs (although some of use never have a problem with minimum spending at happs, quite the opposite =P ) I believe they are around 7 - 12 dollars regardless of where you get them.
*shrug*
Rampy
EDIT: Some people have used lexan to mount their Tballs but, eh... not sure how I feel about that... also if you knew someone in a metal type shop and showed em I'm sure they could whip something up for you... (or you  could try mounting it sans mounting plate)
« Last Edit: March 04, 2003, 09:58:39 am by rampy »
Kane
  • What?
« Reply #4 on: March 04, 2003, 12:52:18 pm »
ok, now I'm confused....If I get the Happs Trackball mounting Kit, do I also need to get the Trackball plate? I think not, but I want to be sure.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #5 on: March 04, 2003, 03:21:37 pm »
I notice all the Americans go through the Happs web site to buy.... Do your larger cities not have a distributor out of one of the bigger amusement companies? My city has a happs distributor... I just waltz in, pick up whatever I want and that's it. No shipping charge, no $25 minimum. It just seems odd that you have to go through mail order in your own country and I'm in a different one and don't have to.
If you build a frankenpanel, chances are I don't care for you as a person.
eightbit
  • My cab is never done...
« Reply #6 on: March 06, 2003, 12:53:32 pm »
The US is a big country. Do all the cities in your country have a Happs distributer? Your just lucky thats all.
