Author Topic: Seeburg Tormat Questio  (Read 5074 times)
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« on: May 18, 2006, 08:50:26 pm »
I have an "Entertainer" juke that won't pickup a record.  I listed it on ebay 3 times, and the first 2 some zero feedback jerk bought it and never contacted me.
The last time, I did paypal immediate payment required and that wen't nowhere.
Anyway, some good fellow emailed me during the last auction to tell me that there might be 2 wires disconnected on my tormat unit that is causing my problem.
I took two screws off the front of the tormat, cut the warranty tape  ;D, and the cover won't come off.
Are there any other places to check?  Looking into my crystal ball, searching for all knowing Ken.
Thanks  Jacktucky
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
xk
  • Last login:July 09, 2025, 05:18:37 am
Re: Seeburg Tormat Questio
« Reply #1 on: May 19, 2006, 06:09:26 am »
Hi
 I had this problem on a Seeburg jukebox,it is a very common fault,an ex Seeburg engineer told me the fix.
If you look at the tormat unit under the record rack you will see a thick phono type cable
follow this cable to where it meets the mechanism control panel
you will find it conects via an RCA/phono plug
What happens is you get slight corrosion on this plug and socket (especially if the jukebox has been kept in a damp environment)
All you need to do is clean the plug up and perhaps squeeze it a bit to make sure of good contact.
If this doesn't fix it there is a good fault finding link below
http://www.flippers.com/Seeburg-trblshoot.html
JackTucky
« Reply #2 on: May 19, 2006, 09:05:52 am »
That did it.  That cable is all messed up.  If I fool around, I can get it to pickup the right record, move it again, it picks up every record.
cool, looks like if I just fix that cable, I'll be OK.
THANKS
Jacktucky
Ken Layton
  • Guru
  • Technician
« Reply #3 on: May 19, 2006, 11:30:29 pm »
Tony Miller's SEEBURG website has excellent troubleshooting information on this system since he invented it!
Check out:
http://home.pacbell.net/fmillera/
