Author Topic: Any suggestions for joystick dust washer material?  (Read 1605 times)
Luckydevil
  • Last login:August 02, 2007, 01:38:45 pm
  • mmmm.... kilowatts.
    • Garage Junkies
« on: May 13, 2006, 11:18:19 pm »
I just added wico balltops to my P360's and the holes on the dust washers are now too big.
Any suggestions as to what I should use to cut out a new pair of these? I know of course they are plastic, but I was hoping someone knew where I could get something in similar thickness and texture to cut these out of.
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
Re: Any suggestions for joystick dust washer material?
« Reply #1 on: May 13, 2006, 11:53:44 pm »
Gahhhhh! I just recently threw away something you could have used! I had a used door panel...I used the plastic from the pocket on the door to make a face plate for my car stereo. I will see if we have any more door panels that have cleared and I can have.
Xam
Can't talk to a psycho like a normal human being.
19rjs99
  • Last login:January 30, 2019, 08:31:31 pm
« Reply #2 on: May 14, 2006, 12:48:59 am »
Use Plexi or Lexan. Cut it with a hole saw. and sand it smooth on the edges. Paint it with Krylon Fusion and your all set. You can make any size you need.
Bob
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #3 on: May 14, 2006, 04:55:07 am »
I used packagings on CD. External black side has identical texture.
http://www.kupsprzedaj.pl/view-picture.asp?FileName=original/2/7/3/1730638017-PUDNONCDSL101.jpg
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #4 on: May 14, 2006, 01:39:49 pm »
PM sent.  I have some for you.
Luckydevil
    • Garage Junkies
« Reply #5 on: May 14, 2006, 02:39:28 pm »
Thanks a ton, much appreciated.
Thanks for the other suggestions too guys.
« Last Edit: May 14, 2006, 09:18:45 pm by Luckydevil »
