Author Topic: Sterring wheel not working on a Mamewah/mame/cabinet  (Read 1949 times)
hayabusa_fmw
  • [Provisionally returned]
  • Last login:December 30, 2014, 03:24:56 pm
« on: May 03, 2006, 02:43:11 pm »
Hello guys
It seems i cannot make work my old Thrustmaster t2 Sterring wheel with my mame cabinet  I am using mamewah, & dos mame i think
The thrustmaster connects to the Game port + i have calibrated it fine.
I am using an x arcade aswell but it connects via ps2 so it doesn't really have to interfer with anything....
In mamewah theres a place with Mouse 0 , joy 0  ( I set them to 1 all of them for the heck of it because it was (0 = off  1 = On)
doesn't work either
I go in the game Press Tab = try to configure it Hit any key on the sterring doesn't move....
how can i fix this?
thanks!!!!
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
Re: Sterring wheel not working on a Mamewah/mame/cabinet
« Reply #1 on: May 03, 2006, 04:29:13 pm »
Does your MAME cabinet have windows installed?
If the joystick is digital, I'm not sure Dos can recognize it via the Gameport.  I remember back in the day when digital joysticks first came out, there were a lot of problems trying to get them to work with DOS games.
hayabusa_fmw
« Reply #2 on: May 03, 2006, 05:22:39 pm »
so it would never work, ....?
this sucks tho many of older device were made Game port wise.
i would need a USB one...?.....
ArcadEd
    • Arcade-In-A-Box
« Reply #3 on: May 03, 2006, 05:26:39 pm »
Probably your best bet would be to upgrade to windows for the OS and windows mame.
I'm not sure if any steering wheel will work in DOS Mame unless it's a mouse hack.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: May 03, 2006, 07:33:42 pm »
ArcadeEd, the T2 wheel is so old apparently was designed for dos (link 1 and link 2), so all is needed are the right drivers and tell dmame what type of driver you have.
And hayabusa_fmw, are you sure you are using dos mame ('dmame.exe' since before 0.53), not windows commandline mame, aka official mame, aka mame, aka "mame.exe"?  I haven't used dmame for a long time, so hopefully someone else can help.  If you have mame.exe and it's not 4 years old, it is not dos mame and more people know how to help you.
Robin
Knowledge is Power
hayabusa_fmw
« Reply #5 on: May 03, 2006, 08:34:42 pm »
I am using The mame Binary + mamewah.....
I really don't know what you mean
I think i have official mame
http://www.mame.net/downmain.html
I got it from there back then.
I got the THRUSTMASTER FORMULA T2
not the one with the blue pannel
I am using Windows XP + theres an incorporated driver T/2  With adapter so i Choosed it + it works i calibrated it
but it's not working in mame when i hit TAB in game to change the steering atributes
like I press the gas pedal doesn't change....
doesn't see it seems like.
« Last Edit: May 03, 2006, 08:55:00 pm by hayabusa_fmw »
« Reply #6 on: May 04, 2006, 05:13:50 am »
As you got MAME from mame.net I assume you are using Windows Commandline MAME (not Dos MAME).
Setting 'joystick 1' in your \mame\mame.ini is the easiest way.  Alternatively you could use the _device settings...
hayabusa_fmw
« Reply #7 on: May 04, 2006, 09:51:54 am »
im not sure what you mean?....
I put Joystick 1   (on/off)    = 1 on   0 = off
(in Mamewah , CTRL) default.ini
(i dont have a mame/mame.ini  remember im using the binary )
still doesn't work....
I don't get it.
« Last Edit: May 04, 2006, 09:59:13 am by hayabusa_fmw »
Forces21
  • Last login:March 02, 2011, 05:05:48 am
« Reply #8 on: May 04, 2006, 11:58:00 am »
What MinWAH is trying to say to you is that you SHOULD have a mame.ini file within youre MAME directory, NOT the ini file from within MameWAH. If there isn't a MAME.INI then use RUN from the start button and enter the program as being CMD & then press OK.
You are at a command prompt. Now say you have MAME on E drive in a directory called MAME, you would need to type the following where <Enter> is the enter key
E: <Enter>
cd MAME <Enter>
mame -cc <Enter>
exit <Enter>
(Just replace the E: with the drive your MAME directory is on etc.)
You can then use explorer to go to the MAME folder & enit the MAME.INI file that has been created. Within here you need to set Joy = 1.
Then you should be able to configure the game from the TAB screen & should recognise the buttons & steering wheel / pedals.
« Last Edit: May 04, 2006, 12:00:03 pm by Forces21 »
