Author Topic: Slikstick, Ms Pac-Man 4-w and Super Joystick  (Read 1678 times)
iamnaeth
  • Last login:August 08, 2018, 02:42:59 pm
« on: April 16, 2006, 05:27:30 am »
Well, i made an impulse buy the other day and picked up 2 slikstick stainless steel joysticks for my competition joysticks in addition, I bought a stainless steel and super joystick with the intention of using them exclusevly for 4 way games.  Apparently, after a little further review, this things aren't so hot for 4 way PLUS oscar controls and their restriction plates are gone.  Everyone says that the replacement joystick for the MS Pac-Man/Galaga game is a fantastic 4 way.  My question is, will the slikstick balltop shaft I bought for the super joystick fit in the replacement joystick?  I can't seem to find exact dimensions on the slikstick or super joystick shaft but I know that the replacement joystick has .394" according to the happscontrols website.  Thanks!
Nate
amerish
  • Last login:June 20, 2015, 11:01:33 am
  • Why build 1 when you can build 2 at twice the cost
    • You Saw It On TV
Re: Slikstick, Ms Pac-Man 4-w and Super Joystick
« Reply #1 on: April 16, 2006, 08:18:10 am »
I also had a ms. packman but did not light the height of the stick.  I also purchased from slickstik the lighted ball top.  I was able to replace the ms. packman stick with the stick from the ball top without any difficulty.  I do find that the feel of the stick is not excellent but way better the the lighted ball top in 4 way mode.
I also swapped the bottom of the joy sticks so the slickstick wiring would not dislodge. No problems, the screws line up perfectly.
Best advise, give it a try, if you don't like it, just change it back. Took me about 15 minutes to change it.
iamnaeth
« Reply #2 on: April 16, 2006, 09:10:06 pm »
I appreciate your response but I'm just a little confused by your answer.  Is the diameter of the shaft in the Ms. PacMan / Galaga Stick and the the diameter of the Happs Super stick the same?
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #3 on: April 16, 2006, 09:32:54 pm »
yes. you can interchange the shafts of those two joysticks.
although i think the slikstik shafts and knobs are gorgeous, i prefer the shortest possible throw for 4-way games. for details about the best 4-way solutions (IMHO), follow the web link in my signature and scroll down to the "Components" section.
if i were starting from scratch, i'd use the betson space invaders stick for wood panels and the stock ms pac / galaga reunion stick for metal panels.
to see my "Frankenpanel" and design notes, click here.
