Author Topic: Groovygamegear Spinner Question **SOLVED**  (Read 1308 times)
oldskoolcade
  • Last login:March 26, 2021, 11:46:36 am
« on: April 06, 2006, 08:13:49 pm »
Just got my spinner (yay Randy!)
Maybe I'm dumb (my wife seems to think so most times), but I can't figure out how to adjust the height of the shaft so I can make it fit my control panel.  On the site it says to loosen the set screw, but I don't know which that is or where.
Anybody with some info that could help a dumb guy out, would be appreciated!
Cheers!
Mike
« Last Edit: April 06, 2006, 10:57:18 pm by oldskoolcade »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Groovygamegear Spinner Question (actually help)
« Reply #1 on: April 06, 2006, 10:37:26 pm »
here ya go!
you will need a small allen wrench to loosen this screw.  Then pull the shaft up to the height you need and retighten the set screw.  Be sure not to over tighten.
oldskoolcade
« Reply #2 on: April 06, 2006, 10:56:17 pm »
Thanks dude!   The second I saw your post, I got an e-mail from Randy explaining the same thing  :D
As I said to him, I knew it was a simple solution...it's just that I'm a little slow today  :P
Cheers!
Mike
