Author Topic: Mame's press left then right message  (Read 8058 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« on: April 06, 2006, 03:52:09 pm »
Does anyone know how to disable (if able to) the intro message when you load a rom that asks you to press any key or to press left and right?
Virtualmatt
  • Last login:August 27, 2007, 10:47:07 am
  • Unofficial International Whack-a-Mole Champion
    • Virtualmatt.com
Re: Mame's press left then right message
« Reply #1 on: April 06, 2006, 03:56:05 pm »
The only way I know how to get rid of it is to press the joystick left, and then right  :-\
I was wondering the same thing, though.
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« Reply #2 on: April 06, 2006, 04:03:53 pm »
i believe you have to edit the source code for that.
"Don't play pinball if you only got one arm, cuz your score will suck."
ahofle
    • Arcade Ambience Project
« Reply #3 on: April 06, 2006, 04:05:09 pm »
It used to allow you to bypass with a command line switch I believe, but that was removed.  I sure hope PowerMAME revives this.
pointdablame
  • Last login:Yesterday at 10:31:29 am
« Reply #4 on: April 06, 2006, 04:13:01 pm »
you can skip some of the disclaimers by altering the mame.ini file. Other error messages cannot be stopped (at least in older versions.. I'm not using a recent version) unless you compile your own version of mame.
first off your and idiot
Lilwolf
« Reply #5 on: April 06, 2006, 04:13:43 pm »
It only does it once now so its not as bad as it used to be.
But yes, nice to get rid of....   I think mameplus does it.
Farmboy90
  • Last login:June 26, 2006, 12:15:04 am
  • My cab is done... Pics coming soon!!
« Reply #6 on: April 06, 2006, 04:43:26 pm »
Make this change in your source (this was based on v.102:
http://forum.arcadecontrols.com/index.php?topic=49097.0
ahofle
« Reply #7 on: April 06, 2006, 04:50:32 pm »
Awesome, Farmboy.  So is this going to be part of PowerMame?  Or does this make the mamedevs unhappy?
Farmboy90
« Reply #8 on: April 06, 2006, 05:08:29 pm »
If it was up to me it would be.  My solution is different than most people's because it does NOT remove these screens.   It simply adds BACK into MAME the support for the configuration flags.  The user can choose to enable them or disable them.
For some reason this is a big religious issue.   ::)  And I don't care what the decision is, since I will just make this change on  my own anyway.
At any rate, I don't think this will be in PowerMAME.  I offered to add it and provided the tiny source change but it seems the powers that be don't want to go there.
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #9 on: April 07, 2006, 11:24:36 am »
I'm pretty sure you can just add the switch -frames 1 or something like that (anything less than a certain number is just a test mode that disables all warning screens), and through the process of some crazy math, 2 is subtracted from 1 and it shows -1 frames, which is impossible, so the game plays normally, although it's technically in a test mode.
If you put any number other than 1, it exits after that many frames.
don't shoot me if i've got this one wrong.
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« Reply #10 on: April 07, 2006, 12:32:00 pm »
I don't know why this message is annoying for you. It appears only the first time you load the rom... ???.
And yes, MameDevs want this message appear.
botman
  • Last login:May 06, 2009, 01:11:02 pm
  • There is no spoon.
« Reply #11 on: April 07, 2006, 07:34:22 pm »
See, "-[no]skip_gameinfo" and "-[no]skip_disclaimer"...
http://www.mame.net/readmewin.html
The default is "-noskip_gameinfo" and "-noskip_disclaimer"
I just wish there was a "-skip_selftest" option to cause games to skip the selftest at boot time (but that would be a little difficult since each game would have implement this by hacking the boot sequence).
Farmboy90
« Reply #12 on: April 07, 2006, 07:39:50 pm »
This is happening actually.  It may already be done, I haven't checked in on the thread in a while.  But over in the Software forum there was some work being done to document the number of frames each games uses for the boot sequence.  That could all be tabulated in a file and then the code could be changed to skip those frames when loading that game.
I think it was going to be in PowerMAME.  Not sure of the current status though.
davieboynj
« Reply #13 on: April 09, 2006, 02:36:38 pm »
http://www.powermame.com/pmwiki.php?n=Features.DisclaimerOptions
"For MAME 0.79 thru 0.99u2, the last two screens may also be bypassed by either sending "-ftr 1" after the game name, or by adding "Frames to Run 1" to either the mame.ini file or the individual gamename.ini file. (Thanks to Howard Casto for discovering this). "
I'm (NOT) still using this in .104 with success.
« Last Edit: April 10, 2006, 05:28:53 pm by davieboynj »
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #14 on: April 09, 2006, 05:56:13 pm »
I'm the same. Whats the big deal. It's a once only affair and there is no pain whatsoever.
Brad
quarterback
« Reply #15 on: April 09, 2006, 06:39:13 pm »
I have to hit "OK" (or right/left joystick) every time on many games before they'll start.  Not just the first time they're loaded.
EDIT: to note that I'm using .55   Yes it's old, but so am I :)
« Last Edit: April 09, 2006, 06:51:56 pm by quarterback »
-- Chad Tower
botman
« Reply #16 on: April 09, 2006, 06:50:46 pm »
Older versions of MAME require you to press "OK" everytime the game is run.  Newer versions of MAME only require to you to do it once, the first time you run it.
One of the advantages to older versions of MAME is that it starts up a bit quicker than the more recent versions.  Try running one of the really old DOS versions of MAME and compare the startup time to the most recent version of MAME.
MYX
    • MYX Digital Blog
« Reply #17 on: April 09, 2006, 06:56:02 pm »
You could get a couple of these and label them o and k and mount them smack dab in the center of your CP. And you could make em blink so you know right where they are.  ;)
M    Y    X
Havok
  • Trade Count: (+17)
  • Last login:August 18, 2025, 12:44:57 am
« Reply #18 on: April 09, 2006, 11:19:22 pm »
haha - I think you should replace ALL the buttons with those!
Me, I just re-compiled my version. I don't need no stinking OK...
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #19 on: April 10, 2006, 12:26:59 am »
left and right?
bah... back in my day we had to wire up O K buttons for this tasks....
uphill both ways in 6 inches of snow....
davieboynj
« Reply #20 on: April 10, 2006, 01:30:00 am »
I'm gonna get a freakin' complex if someone doesn't respond to this.    :banghead:
if you use these options:
mame invinco -skip_disclaimer -skip_gameinfo -skip_validitychecks -ftr 1
you will never get any screens.  NEVER.  EVER.
Havok
« Reply #21 on: April 10, 2006, 06:00:37 am »
Did you hear something? I thought I heard something... Nahhh....
 :angel:
MYX
    • MYX Digital Blog
« Reply #22 on: April 10, 2006, 08:09:30 am »
musta been the wind blowin. er somethin.  ;)
M    Y    X
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #23 on: April 10, 2006, 11:53:26 am »
I wish there was a way to avoid those annoying boot screens.     :'(
mrC
quarterback
« Reply #24 on: April 10, 2006, 12:10:52 pm »
I'll respond
When I use those options, I get:
error: unknown option -skip_disclaimer
error while parsing cmdline
Only has to be shown to be wrong in one case to prove your "NEVER. EVER" hypothesis to be erroenous.  Done and done.  Let the head-banging resume ;D :banghead:
« Last Edit: April 10, 2006, 12:17:08 pm by quarterback »
-- Chad Tower
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #25 on: April 10, 2006, 12:32:48 pm »
I'm thinking 'bout making the OK cab.
The control panel would ONLY contain two of these buttons.
No joysticks, spinners, nothin'.
You just keep hitting "O" then "K".
That would some awesome fun!
In the voice of Special ED - "YEA! I'm pushing buttons, YEA!"
Half of the people you meet are below average.
ahofle
« Reply #26 on: April 10, 2006, 02:44:01 pm »
I'll respond
Heh.
Not to mention the "-ftr 1" just boots you out of the game immediately.
davieboynj
« Reply #27 on: April 10, 2006, 05:26:44 pm »
well, at a minimum i don't have a complex anymore.   ;)   Here's what i found:  I am in fact running a .96 version of mame, and a 104 version of mame32.  This would explain the aforementioned errors when running with 104.
HOWEVER...  (let me try this again)
if you use these options (with any version from 0.79 thru 0.99u2) :
but you'll still be playing invinco.
and i hate all of you.   ;D
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #28 on: April 11, 2006, 01:21:44 am »
I'm running Mame32 v.94.  I go to Options->Default Game Options, select the Misc. tab, and check the "Skip Disclaimer" box.
Gosh, doesn't anyone at least look at the options of the software. :banghead:
[Sorry if I'm sounding like a jerk here, but my DSL modem isn't "synch'ing" and I'm on dial-up  :badmood:]
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #29 on: April 11, 2006, 04:58:51 am »
Agreed, that sucks worse than the ok screens.... I need a turtle smilie... :angry:
My Websites
danny_galaga
  • Last login:August 27, 2025, 12:48:54 am
    • dans cocktail lounge
« Reply #30 on: April 11, 2006, 07:49:51 am »
damn, im on v78 so i guess i miss out  :(
ahofle
« Reply #31 on: April 11, 2006, 11:20:42 am »
Gosh doesn't anyone at least read the thread before replying to it?  ;)
THAT OPTION WAS RECENTLY REMOVED FROM MAME.  The last few revisions of MAME have some important fixes like perfect sound in Phoenix, so I don't want to go to an older version (before you ask).  ::)
Havok
« Reply #32 on: April 11, 2006, 11:29:35 am »
Learn to re-compile, and all is well. I don't need to specify any command line options!
And thank the Mamedevs for Phoenix - that is one of my favorite games, I've been waiting for quite some time. Now... Star Wars Trilogy!!!
