Author Topic: 4 joysticks PLUS a dedicated 2/4-way??  (Read 1962 times)
mkdevo
  • Last login:February 09, 2024, 09:31:59 pm
« on: February 25, 2003, 03:00:07 pm »
hello all,
pardon the newbie question, but i'm looking to do a 4-player setup, and have a seperate joystick for 2/4-way games.. is this possible with just a 4-player ipac, or do i need something else for this? i'm looking at something like this:
http://www.cybercoma.com/supercade/control_panel.shtml
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:4 joysticks PLUS a dedicated 2/4-way??
« Reply #1 on: February 25, 2003, 03:06:58 pm »
ugh, another 4 player panel =P
You can certainly use the 4player ipac.  If inputs become an issue (I'm too tired to do the math right now) you can simply wire the dedicated 2/4 way in parallellellellell with another joystick .
*shrug* next!
rampy
mkdevo
« Reply #2 on: February 25, 2003, 03:11:04 pm »
thanks rampy... that's kind of what i was wondering - if you could 'piggyback' multiple controls to one input... thanks!
rampy
  • *shrug*
« Reply #3 on: February 25, 2003, 03:17:22 pm »
np, just don't let friends screw you up in a game by "accidently" bumping the 4 way (assuming its wired in parallel to whatever stick you are currently playing on) causing you to break your "block" or fall into a pit or something =P
good luck with your project!
rampy
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #4 on: February 25, 2003, 03:36:21 pm »
To keep the extra joystick from messing up player 1 or whatever as rampy describes, you could put an A/B switch on their grounds, so that only one can be engaged at a time.
I'd suggest either a slider/toggle switch or a light up button that'll indicate when the 4 way is engaged, so you don't get your first guy killed using a dead stick.
You can still wire all the directional switches in parallel, but the commons/grounds would go to the switch, which would then go on to the iPAC.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #5 on: February 25, 2003, 05:10:23 pm »
Good idea
-Ace-
I want my own arcade controls!
