Author Topic: SlikStik Tornado Spinner and Ultimarc Opti-Pac  (Read 2406 times)
Santo8742
  • Last login:September 11, 2015, 06:48:39 pm
« on: March 30, 2006, 10:51:02 pm »
Newbie here with an interface question.  I just purchased the Tornado Spinner from SlikStik with the new Mini-Pac/Opti-Pac interface cable and I need help hooking it up to the Opti-Pac.  The spinner has four cables connected at the end with a small red connector which I'm assuming is to connect it to the Min-Pac.  I'm guessing I have to cut off the connector and plug each wire into the corresponding spot on the Opti-Pac.  The problem I have is I don't know what the wires are.  The wires are black, yellow, green, and purple and I'm guessing one is ground, one is 5v, one is X1/Y1, and one is X2/Y2 can anyone tell me what wire is what?  Thanks for the help.
Santo8742
Re: SlikStik Tornado Spinner and Ultimarc Opti-Pac
« Reply #1 on: May 16, 2006, 02:42:08 pm »
Does anyone have the answer to this?  I don't want to plug the wrong wires in the wrong spots, I think it probably wouldn't be good to plug a power wire into an axis slot.  Any help would be appreciated.
Havok
  • Trade Count: (+17)
« Reply #2 on: May 16, 2006, 03:07:17 pm »
I'm more on the GGG side, but try e-mailing their tech support:
info@slikstik.com
« Last Edit: May 16, 2006, 03:09:03 pm by Havok »
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: May 16, 2006, 03:11:59 pm »
Hopefully this will help:
Santo8742
« Reply #4 on: May 16, 2006, 06:05:36 pm »
That picture was exactly what I needed.  The colors are Black: gnd, Yellow: X2, Purple: X1, and Green: 5v. Thanks Andy.
