January 27, 2026, 08:04:56 am
I have been trying to keep up with all the features and options. It ain't easy. I am sure it is answered in another thread but the question I had was regarding the lighting of the controls that a game uses. Can you set the colors that each button will be(assuming you have rgb leds) for a specific game, or when you set the colors is it done globally. I saw that there was a lighting override option where you put the gamename.lsq file in the lighting directory, is this where you would set the colors for a specific game? If so, instead of using the gamename could you use the bios name, for instance neogeo?Thanks
