Author Topic: Question on lighting configuration  (Read 8457 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: March 27, 2006, 10:35:29 am »
I have been trying to keep up with all the features and options.  It ain't easy. :)
I am sure it is answered in another thread but the question I had was regarding the lighting of the controls that a game uses.   Can you set the colors that each button will be(assuming you have rgb leds) for a specific game, or when you set the colors is it done globally.  I saw that there was a lighting override option where you put the gamename.lsq file in the lighting directory, is this where you would set the colors for a specific game?  If so, instead of using the gamename could you use the bios name, for instance neogeo?
MikeQ
Re: Question on lighting configuration
« Reply #1 on: March 27, 2006, 10:43:55 am »
In your LEDWiz.cfg file there is now an intensity parameter.
You can use this parameter to set the RGB values for a button.
You will need 3 entries for the button as follows:
LEDWiz   LED          Button
output    intensity   keycode
1            48             KEYCODE_A
2            48             KEYCODE_A
3            48             KEYCODE_A
Popcorrin
« Reply #2 on: April 29, 2006, 01:15:04 am »
So is there a way to set up individual games differently.  For instance if I wanted the buttons 1-4 to be the proper color when I play a neo geo game (red,yellow,green,blue) but in other games I want the buttons to be lit blue is this possible?
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #3 on: April 30, 2006, 11:11:42 am »
I think all you need to do is make a NeoGeo config with the PowerMame options in it.
MikeQ
« Reply #4 on: May 01, 2006, 08:35:17 pm »
Make a gamename.lsq file in the lighting directory with the names of the .lwa files you want executed for that game.
