Author Topic: Coin door  (Read 1358 times)
dpz147
  • Last login:March 18, 2020, 11:49:34 am
Coin door
« on: March 22, 2006, 03:46:22 pm »
Can anyone point me to a good tutorial on installing a coin door?  I finishing up my first cab, so I'm a total noob and I'm not sure how to set up the coin door to accept tokens.  I did a search here, but didn't come up with much.
How do I connect it to my power supply?
How do I switch it from quarters to tokens?
I'm assuming I wire it to coin1 and coin2 on my KeyWiz.  Is that correct?
Any help would be greatly appreciated!    ;D
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: Coin door
« Reply #1 on: March 22, 2006, 03:52:13 pm »
you will have to make a harness to hook lights to your coin door, also you will have to switch the meches to token mechs to accept tokens, cant help you on the keywiz, i have only used the ipac
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
dpz147
Re: Coin door
« Reply #2 on: March 22, 2006, 03:58:35 pm »
How do I create the harness and switch the meches?  By harness, do you mean mounting a light behind the door?
On the ipac, do you just run a wire to coin1 and coin2?
Thanks for your help.
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: Coin door
« Reply #3 on: March 22, 2006, 04:00:15 pm »
Yep that all you need to do here is a good article to help you out
http://www.retroblast.com/articles/token-convert.html
I posted on the other thread
dpz147
Re: Coin door
« Reply #4 on: March 22, 2006, 07:05:07 pm »
Retroblast has a link to an article on how to modify the coin mech without having to change parts, but the link doesn't work.  Does anyone know how to do this or know where I can find the article?
dpz147
Re: Coin door
« Reply #5 on: March 22, 2006, 07:18:45 pm »
dpz147
Re: Coin door
« Reply #6 on: March 23, 2006, 11:04:50 am »
Well...after hours of research on modding coin mechs for tokens...I just tried a Chuck E. Cheese token...and it doesn't even fit in the coin slot!!  :-\
Has anyone ever lengthened a coin slot with a dremel?  I saw it referenced in the thread I linked above.
Any other ideas???
divemaster127
Re: Coin door
« Reply #7 on: March 23, 2006, 11:18:38 am »
This is just what i would do, you have to look at your time, their are seveal sizes of tokens you can get that you do not have mod your door & mechs are not expensive, i would just use a smaller token & change the mech it takes 30 minutes, again this is what i would do
dm
divemaster127
Re: Coin door
« Reply #8 on: March 23, 2006, 11:19:19 am »
Chuckie cheese tokens are .900 you are going to want a smaller size
dm
dpz147
Re: Coin door
« Reply #9 on: March 23, 2006, 12:14:54 pm »
I thought I read somewhere that they were .984?
Havok
  • Trade Count: (+17)
  • Last login:August 18, 2025, 12:44:57 am
Re: Coin door
« Reply #10 on: March 23, 2006, 01:53:39 pm »
I think so - Santoro is the expert here, he would be able to confirm...
dpz147
Re: Coin door
« Reply #11 on: March 23, 2006, 02:43:19 pm »
Does anyone know what size a quarter is?  I' ve seen .880 tokens being sold and as long as they're smaller than a quarter I should be ok.  Right?
