Author Topic: anybody have any Ms Pacman or Galaga bartop plans?  (Read 13234 times)
bishmasterb
  • Last login:March 23, 2014, 09:27:47 pm
  • Pressing the limits of my wife's patience...
    • Bishopzone
Re: anybody have any Ms Pacman or Galaga bartop plans?
« Reply #40 on: March 28, 2006, 09:03:32 pm »
Sorry to nitpick, but the plans look more like they are based on Pac-man/Galaxian rather than Ms Pac-Man/Galaga.
Oh, feel free to nitpick. :)  They are definitely not intended to be an exact replica by any means (they are a bartop afterall). In fact, I wanted a cab that could reasonably be a Pac Man, Galaga, Ms. Pac Man or Galaxian. I just thought it would be really cool to have several lined up together, each with different artwork, color and controls. And of course it goes without saying that I don't think any of those had a vertical monitor setup (at least Pac and Ms. Pac didn't).
But point taken, if you're building an exact replica, these plans are not the way to go by any means.
"We have just enough religion to make us hate, but not enough to make us love one another." -Jonathan Swift
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #41 on: March 29, 2006, 08:51:38 am »
Lol, no of course not. It was more that the question was for the Galaga/Ms-Pac shape explicitly. Anyway, one could easily change the sides a bit to look more like a Galaga/MS-pac shape. Nice plans BTW!
sWampy
  • Last login:February 02, 2010, 04:23:40 pm
« Reply #42 on: March 29, 2006, 09:41:42 am »
Unless you use like a 7 inch monitor, that is going to be hard to do, unless you just want the sides stuck on that don't go with the monitor position, even then it will look way to short and fat.
http://www.landoncrews.com/mspacmantop.dwg
bishmasterb
    • Bishopzone
« Reply #43 on: March 29, 2006, 10:36:37 am »
I intended that one could make different styles of cabinets simply by cutting the sides differently. The top curve and the large front concave curve of the Namco cabinets could be cut differently to reflect different styles of cabinet. I was planning on making a Williams series of cabinets using these plans with alterations to the sides, but haven't got around to it.
Hopefully someone will try it, I'd like to see it.
sWampy
« Reply #44 on: March 29, 2006, 11:38:57 am »
Here is a williams inspired side that should fit.
http://www.landoncrews.com/defendertop.dwg
Or even Crystal Castle.
http://www.landoncrews.com/crystalcastle.dwg
« Last Edit: March 29, 2006, 01:42:47 pm by sWampy »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #45 on: March 30, 2006, 03:10:58 am »
Why did you move the control panel up? The pointy bit in the side (where the CP is) should be at roughly the same hight as it is in the original version. Otherwise the control panel wont fit will it? Just slide the "pointy bit" down (lengthening the straight line of the front top) and maybe straighten the kickplate (I guess it will look silly at an angle if its so short). Or am I overlooking something why you moved it up?
« Last Edit: March 30, 2006, 03:19:06 am by patrickl »
sWampy
« Reply #46 on: March 30, 2006, 08:48:21 am »
I left it up, cause to me, it lost all looks of of the galaga/ms-pacman, and looked almost identical to Bishmasterb's side.  If you want them to really want the profile to remind you of galaga/defender/etc you really need the same profile as the original, and just have the side panels being a facade and not true indicators of where the control panel/marqueue/monitor reside.
Zeosstud
  • Last login:July 17, 2025, 10:17:10 am
« Reply #47 on: April 05, 2006, 12:10:38 pm »
I'm not to handy in autocad, but here goes.
http://www.landoncrews.com/Bartop.dwg
http://www.landoncrews.com/Bartop.dxf
These are optimized for 2 4x4 sheets to make it easier to take home.
http://www.landoncrews.com/Bartop2.dwg
http://www.landoncrews.com/Bartop2.dxf
Doesn't work in Firefox, but try this in ie.  http://www.landoncrews.com/Bartop/acwebpublish.htm
I downloaded your bartop.dwg and bartop2.dwg, had no problems with the bartop2.dwg file, loaded right up in Autocad Lt 2002.  The bartop.dwg file however said that it was made in an incompatible version.  Curious if you used 2 different autocad programs to create the files and also what versions you used.  Might have found a person with a Water Laser CNC type setup that will help me cut these out.  His machine can accept a full 4x8 piece of material so the bartop.dwg thats not optimized for 2 4x4 sheets could be very useful.
sWampy
« Reply #48 on: April 05, 2006, 12:30:55 pm »
Most of them I remembered to save as for older versions, a few I guess I forgot.  I can make you layouts for any of the sides optimized for 4x8 sheets, optimized in several different ways.  I have a program that optimizes for easiest cuts, fewest cuts, most board left over, biggest pieces left over, etc.
Zeosstud
« Reply #49 on: April 05, 2006, 03:53:33 pm »
sWampy,
                 It would be super to get an autocad drawing for a full 4x8 sheet that I can open in AutoCad Lt 2002.  I also have access to Autocad 2006 and Autocad 2006 Lt.  I am hoping to get with a coworker of mine who has a friend with access to a water laser cnc deal, hoping to feed this .dwg file into it and have it spit out the parts cut and ready to assemble.  If you wish to attach that file to an email just send it to  butlerrodney@hotmail.com  I will also monitor this thread if you prefer to post it here.  Thanks for you time and effort.  If all this comes together I will try and gets some pictures of the whole process and post em.
Zeosstud
sWampy
« Reply #50 on: April 05, 2006, 04:06:07 pm »
Give me a couple of days, i don't have any time to work on it till the weekend, and if you really want to have the cut that way, I should take the time and make them correctly.  Right now, they don't have any of the internal holes detailed, ie speaker/fan holes, etc.   I threw them together quickly, just to give people a layout idea, I hate having to make patterns and try to arrange them on a piece of plywood to figure out the best way to cut them.   I figured with the quick layout, you could make one with just a tape measure, a straight edge, and a saw, and just eyeball the curves. ;-)
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #51 on: April 05, 2006, 10:38:27 pm »
Sorry, but that just doesn't make sense. The Pacman version Bishmaster made is based on the same principle. Basically you cut off the bottom part and yer done. Why would this only work for the Pacman cab? The straight front and the sloped top make it a galaga/ms pac-man. It looks similar of course, but that's ... well ... because they are. Anyway ...
sWampy
« Reply #52 on: April 05, 2006, 11:28:16 pm »
When I took a galaga drawing, cut it off below the control panel, and then enlarged it to the same dimensions as Bishmasters, making sure the top came forward enough to enclose the monitor, it ended looking almost 100% like bishmasters.   I guess it just comes down that to me, if you really want it to look like a pacman/galaga/crystal castle/etc you need the whole profile, not just from the control panel up.   I frankly like the original design, it is a fairly generic look, that reminds me of arcade without pointing to any particular one.
I think I'm going to make me a couple with williams like sides and make me a mini stargate with the correct control panel, and a sinistar.   I might even make a mini tron.
Zeosstud
« Reply #53 on: April 08, 2006, 12:07:19 pm »
sWampy,
                Just a note to let you know I am still checking.  Got a piece of scrap wood heading over to the guy that has the water laser cnc setup.  Should find out monday or so if his machine cuts 3/4" MDF or not.  Have a good weekend.
Zeosstud
sWampy
« Reply #54 on: April 11, 2006, 10:34:06 am »
sWampy,
Zeosstud
I updated these Bartop Plans (ie only, damn autodesk) it's now on 4x8 sheet, and has all the  details included.
The original dwg files is at http://www.landoncrews.com/bartop.dwg and http://www.landoncrews.com/bartop.dxf.  Both were exported to acad 2000 format.
« Last Edit: April 11, 2006, 10:38:22 am by sWampy »
Zeosstud
« Reply #55 on: April 11, 2006, 02:08:09 pm »
sWampy,
                Hey thanks for your efforts again.  I have gotten these plans off to the guy I work with, hoping to get feedback from him if this is gonna work out in the next few days.  Will keep everyone in the loop if anything comes of it.
Zeosstud
Zeosstud
« Reply #56 on: June 01, 2006, 05:34:05 pm »
Hello All,
              Your not gonna believe this, it all actually has worked out.  I now have in my posession the parts to build not just 1 but 2 of these Bartops.  Now I just need to teach myself how to use the whole dowel, dowel center set, drill, glue deal and everything will just fall right into place.  <---  I wish!!!!
Zeosstud
