Author Topic: 8way & 4way Difference  (Read 1788 times)
enfz
  • Newbie
  • Last login:February 21, 2003, 03:36:02 pm
« on: February 21, 2003, 03:20:41 pm »
Hello  8)
I have a joystick, but how do I tell if its 8way or 4way? Any ideas?
Thanks.
_Iz-
  • Last login:August 15, 2025, 07:25:09 pm
  • Time to coin up!
Re:8way & 4way Difference
« Reply #1 on: February 21, 2003, 03:24:11 pm »
Push it into a diagonal and see if it can trigger 2 switches at once...
8-way can trigger 2 at once, 4-way can't...
« Last Edit: February 21, 2003, 03:24:47 pm by _Iz- »
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #2 on: February 21, 2003, 04:19:32 pm »
If it's in a disassembled state see if there is any kind of restrictor plate around the shaft of the joystick. By that I mean is there a palstic or metal plate with a square cutout(points toward the corners), or a diamond(points of the square straight up & down, left&right)
If it's square it's likely to be 8way, if its a diamond, it's a 4way
eightbit
  • My cab is never done...
« Reply #3 on: February 22, 2003, 01:00:21 am »
Hello  8)
Thanks.
Have you read any of the faq that is the basis of this web site? You really should theres a lot of good information here that will help you understand things like 4 way or 8 way joysticks. Some joysticks are even switchable and can do both.
