November 21, 2009, 09:02:18 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: 1 [2]  All   Go Down
  Send this topic  |  Print
Author Topic: How to make a Top Mount or Under Mount Joystick Jig  (Read 24983 times)
Jdurg
Trade Count: (0)
Full Member
Offline Offline
A young guy feeling older than sin......
View Profile
« Reply #40 on: December 25, 2007, 10:28:20 PM »
Very nice.  I've decided to top mount my joysticks so building a jig would be a great way for me to get used to my router.  Thanks for the tips.  I wish Home Depot was open right now because I really want to work on my CP right now.  Cry
Logged
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
clickhea
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #41 on: January 22, 2008, 08:58:30 PM »
how big is that hole for the joystick
1 inch?
Logged
Jdurg
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #42 on: January 27, 2008, 08:45:38 PM »
1 inch?
I'm top mounting the joysticks.  That means it's much bigger than 1-inch, thank you.   Grin
Logged
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
ViciousXUSMC
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #43 on: February 07, 2009, 03:13:59 AM »
Im going to go look at router stuff today so it will probably make more sense later.
The bushing is a piece that mounts before the bit that lets you ride along an edge to guide the cutting bit.  Its at the base of the router so in our case when cutting your actual control panel it would be riding the edge of our template.
However when cutting the actual template you did not use a bushing, instead you used one of those pattern bits with the bearing on the end of it (flush trim bit) and let the bearing guide you instead of the bushing.
Is that correct?  It just seems odd as I thought we used the bushings to eliminate the need for one of the bits with the bearings on it.  You could do it with just a normal bit and a bushing right, or is perhaps the bushing to big to get the corners right.
I guess the final picture confuses me its stained but it looks like the bottom, so you can stick the joystick up through it so this is a bottom mounted build you did right?  If it was top mounted the base of the joystick wont fit through that hole.  But if it is bottom mounted I dont know why the part you wont see was stained?
Then there is the question of terms.  You cut the jig with a bit that has a bearing on the tip, when I googled "flush trim bit" I get those with the bearing at the top: http://www.rockler.com/product.cfm?page=5411
This would work, you could just have the template for the jig on the top instead of the bottom I suppose, also these seem to be popular - http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_flush.html
2nd to last one with bearing at the shaft and the tip of the bit.
For me it seems that I would use the one with the bearing at the top more often so that you can cut into things, if your cutting into something you cant have the bearing on the tip of the bit.
« Last Edit: February 07, 2009, 03:57:02 AM by ViciousXUSMC » Logged
sqwirral
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« Reply #44 on: February 21, 2009, 04:38:46 AM »
Heya Timoe do you have the rest of replies 2, 4 and 5?
There's a bug with the forum, it won't show them
Logged
rockworm
Trade Count: (0)
Full Member
Offline Offline
Got a Q*bert cabinet design going
View Profile WWW
« Reply #45 on: April 20, 2009, 04:37:11 AM »
Maybe a really stupid question but why do you have to sink the joysticks, why can't you simply mount it to the underside?
Logged
sqwirral
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« Reply #46 on: April 20, 2009, 08:58:35 AM »
If the wood is too thick then not enough of the joystick will stick out the top. If the wood is thin enough to do that then you have a flimsy CP. The recess probably keeps it locked in place better too.
Logged
rockworm
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #47 on: April 21, 2009, 01:56:16 AM »
Maybe I was just lucky in my choice of joysticks (some Happ model, don't remember which now) then. I mounted mine under a 12mm fiber board and using four carrier bolts to hold it in place. It is just a temporary control panel used until I start building my cab, so maybe I should try sinking it to know which way to go for the real thing...
Thanks for the help.
Logged
Pages: 1 [2]  All   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.274 seconds with 21 queries.
