Author Topic: Newbie question on touch screens  (Read 1847 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: February 22, 2006, 02:31:59 am »
Do all thin touchscreens im seeing on ebay have a nice hard glass surface? or are they soft like LCD laptop screens? Also in touchscreen jukebox software does a mouse pointer show or is it invisible to the user? Thanks for any help guys...
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
Re: Newbie question on touch screens
« Reply #1 on: February 22, 2006, 02:52:40 am »
Well it depends on what type of touchscreen you buy, LCD or CRT. Crt is hard glass like a TV or standard PC Monitor and LCD is like a laptop screen. The touchscreen part is just an overlay built onto an existing display technology.
As for the mouse pointer showing that depends on the software, i have the ability to turn it off in mine. If the option doesn't exist you can still remove the mouse pointer using the windows mouse pointer themes and a blank mouse pointer theme.
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #2 on: February 22, 2006, 10:44:26 am »
If you want a touch screen that is glass, then you want a "secure touch" monitor. If you buy a touchscreen that was used in a kiosk, then it will most likely have this type. There are some that are glass, but have a film over it. Then you have Carroll Touch, which is a glass screen, but is done with IR instead of touch. You can use gloves even with those.
You can find more info about the different types of screens at http://www.elotouch.com
Negativecreep0
« Reply #3 on: February 22, 2006, 11:55:28 am »
this is cool, i want a screen in the range of 10 - 12 inches taht would be perfect not to big not to small, sadly only small one on eba that are affordable are the ELO monitors and smallest i see are 15". Dont want to spend over 250
clanggedin
  • O'DOYLE RULES!!!
« Reply #4 on: February 22, 2006, 02:22:34 pm »
3M makes Microtouch LCD monitors that are 10" - 12". There have been a couple on ebay recently.
