Author Topic: How far does T-molding stick out?  (Read 1408 times)
Havok
  • Trade Count: (+17)
« on: February 15, 2006, 07:14:00 pm »
Been doing some searching, and I came across one site that lists the "height" of the t-molding sticks out 3/8". This seems a bit much, can anyone confirm this? The reason I ask is that I am making swappable panels and would like to put t-molding around the edge for durability. This raises the issue of how much should I cut the panel down to compensate for the t-molding, as the end-to-end length cannot exceed 28 1/2" - I can't have any overhang on the length, but I'm ok on the width.
I'm still waiting for the t-molding and slot cutter to come in, but wanted to start on the panel. Thanks for any help!
Witchboard
Re: How far does T-molding stick out?
« Reply #1 on: February 15, 2006, 07:18:04 pm »
I think the 3/8" your talking about is the tongue depth.  I think the 19/64" is the measurement you're looking for.
Ya know.. never mind... I'm not thinking right tonight.
« Last Edit: February 15, 2006, 07:27:17 pm by Witchboard »
somunny
  • Is it hot in here?
« Reply #2 on: February 15, 2006, 07:46:38 pm »
Just checked.  1/16th".
Steve
Havok
« Reply #3 on: February 15, 2006, 08:15:31 pm »
Sweet! That was what I was looking for. That's the diagram I came across, and I remembered the 3/8" part. Now 1/16" sounds much better. Strange they left that one measurement out, you'd think people would want to know that one... Thanks guys!
Let the MDF sawdust fly - off to the garage!
AtomSmasher
    • Atomic-Train
« Reply #4 on: February 15, 2006, 08:35:58 pm »
if these measurements are correct then it would stick out 5/64'' which is 1/64 bigger then 1/16''.  although thats probably small enough to not matter.
somunny
« Reply #5 on: February 15, 2006, 08:54:10 pm »
Guess I should have said "approximately"...
