Author Topic: WinCab Font size????????????????  (Read 5014 times)
koolmoecraig
    • My Intervention
« on: February 08, 2006, 09:25:47 pm »
This may be a dumb question, but how do I increase the font sizes in wincab? I'm running on a CGA monitor at 640x288 and the font size is way too small.
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: WinCab Font size????????????????
« Reply #1 on: February 09, 2006, 10:59:10 am »
First off, you'll want to make sure you're using one of the skins designed for low-resolution displays like low-res.skn.  That may solve your problem; if it doesn't, edit the .skn file with a text editor.  To change the size of the fonts on the displays, reduce the number of lines for that display; to change the font size on the title strips, change FontSize and SmallFontSize.
--Chris
--Chris
cscon115
  • Last login:June 12, 2009, 02:45:29 pm
  • Sock it to me!
TEXT ORDER...
« Reply #2 on: February 09, 2006, 12:13:08 pm »
Chris,
Is it possible to swap the order of the Title and group on the CD covers? For example, the CD's are sorted by author
ABBA
Alan Parsons
Beatles
Etc
But... when you look at the CD title I see
0001     Tales of Mystery and Imagination
             Alan Parsons Project
can these be swapped (without releasing your source code)? So it would read:
0001      Alan Parsons Project
I would like the Exact opposite change in the now playing window.
To me... I would like to see the Song / Album / Author (Most specific to most general) but currently the playlist shows Song / Author / Album.
Could these be put in separate skinable blocks or is it too much work?
If you need some C coding done you could copy a small section to me and I could make the changes and send it back. I know... I know... asking for someones source code is like asking them for the use of their toothbrush or sister (it is just not done!)  but ... I feel like a shmuck asking for custom changes on freeware.
Dan
PS - Hay EVERYONE Look for my new thread later today (with pics)!
Ronald Reagan is too liberal for me.
Chris
  • Moderator
« Reply #3 on: February 10, 2006, 08:44:34 am »
Yeah, you're right, that should be selectable; I've swapped them a few times myself.  I'll try to get that in the next version.
--Chris
--Chris
