It's okay but still not totally accurate on the outer edges of the screen (...) I've calibrated it several times and it is always sligtly off to the right.
Ok, this sounds like what I experienced. As far as I'm concerned, this is the only true design flaw of the gun: calibration is *really* flaky.
Still, I was able to get it pretty well calibrated, enough so that it is accurate even at the edges of the screen. So if you haven't yet, make sure you read this wiki, especially the calibration part:
http://wiki.arcadecontrols.com/wiki/LCDTopGunI don't use Windows, but the Linux driver uses the same fixed software calibration values specified in the wiki. I suggest you do the same with Smog's.
Now, for hardware calibration, which as far as I can tell, is the only calibration that matters. Make sure the LED bars are aligned as per the wiki, either vertically or horizontally but with the proper orientation. And if you're going to use the laser pointer for this, *make sure it is properly aligned before you begin*; it loses alignment very, very easily!
Here is where I have to aim the four last shots (after the center shot) to get good accuracy. The square in the middle is the actual screen, the outside square is the TV frame.
x
--o----------------------------o
| | o | | y
I'm not sure how this is going to look on your screen (maybe should've make an actual drawing,
. In any case, center shot is really at the center. But on the edge shots, you have to shoot outside the edges of the screen, not exactly on them. Top shots and bottom shots are respectively at the same y, left and right shots at the same x. However, left shots are closer to the screen (approximately half the distance to the edge of the TV) than right shots , which have to be taken at the very edge of the TV (about double the distance of the left ones).
