Author Topic: is better to make the slope on cp or on the cabinet side where the cp is placed?  (Read 3458 times)
muffin man
  • Last login:February 04, 2017, 03:08:21 am
im trying to have a slope of 1 inch? so any helP?
« Last Edit: January 19, 2006, 06:20:40 pm by mus »
Do you know the muffin man......
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
Re: how do i make control panel box? base and walls that is?
« Reply #1 on: January 17, 2006, 10:05:43 pm »
the top part 4.5"X47" and the bottom part is around 33"X3.5" . I just can't get the sides right.
Don't build the control panel with the slope. Build the bottom part 33"x4.5. Then build whatever the control panel is sitting on (pedestal, cabinet) with the slope.
muffin man
« Reply #2 on: January 17, 2006, 10:57:46 pm »
ahhhh yes what a great idea thks man. now all i need to know is how to connect all 6 peicies to each other
GGKoul
  • Cheesecake Apprentice
« Reply #3 on: January 17, 2006, 11:12:00 pm »
It would make more sense to slope the control panel box...
muffin man
« Reply #4 on: January 18, 2006, 12:17:04 am »
well my plans are based on lusid except for control panel. im sort of leanin on makin the slope on the cabinet itself. it is a pain to make 6 peieces sloped on control panel or if there is a technique some has :)
19rjs99
  • Last login:January 30, 2019, 08:31:31 pm
« Reply #5 on: January 18, 2006, 12:47:46 pm »
If you can't figure out the angles build the bottom box square. Then use a chalk line from the top rear corner to the front edge at the wanted height of the front of the CP. Then cut the box along the line. Not totally accurate but much easier.
muffin man
« Reply #6 on: January 18, 2006, 04:25:05 pm »
yeah i was goin towards taht direction cut can't if i make it box it will run into my buttons and plus the base sides would be stickin out cuz of my top control panel
muffin man
« Reply #7 on: January 18, 2006, 06:24:18 pm »
im making my control panel box itself detacthable so it can get throught doors. just stating this if it means somethin on actual build of cp box.
thank you if some can help
muffin man
anyone ?
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Make just the CP slanted. You will kick yourself if you make the cab slanted. A full MDF cp with box is heavy. If you are trying to make it removable it will mean trying to hold it onto that slant while securing it somehow, which raises another problem. How are you actually going to secure it on there tight enough to keep it on? Gravity does most of the work when it is just sitting on a normal shelf, but it will want to slide down the slant. Most of the time, my CP isn't even strapped down (on my Lusid design cab).
There is a reason you don't see many cabs with the entire CP box slanted.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
muffin man
i c im just having a prolem now now with making the side walls,  i got my top control panel done with joystick and button holes cut out, base (its lenght is same but width is 2 inches less), front wall 47"X4", back wall 33"X3.5",
just need to make sides which are a pain in the ass the get them even.
wish me luck
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
I have pics on how I did it.  If I don't have them loaded on my computer yet, I will tonight.  I made the front and the back, then added the sides.  Once I had that accomplished, I tacked a straight piece of wood that ran from the front to the back and used a flush bit router to cut the wood.  Made a perfect line that was in line front to back.  I did find the pics, too lazy to edit this, hope this helps:
1st pic is with one of the side pieces in and routed already
2nd pic is showing how I mounted the piece of wood as a guide
3rd pic is of the last piece in right before I added the guide piece
More Cowbell
  • That's just dumb!
It's definitely worth the extra time and planning to slant the CP box rather than the cab. You don't want your cab to look saggy.
I've got a fever...
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Show us all the shape that you want to make your CP look like.
There's a definite difference in sloping a CP based on the shape of it, which you need to alert us about before you listen to someone's advice when they have no idea what you're trying to accomplish, specifically.
Use MS Paint to draw your shape, if need be.
muffin man
alright i took some pics with me phone sorry if they don't look that good
angle pic of cabinet
top peice of cp is base as you can its width is 2 inches less than the top cp
ok this is with back and front placed not screwed or glued in need sides now
my control panel (yes i know 8 buttons gonna run console games :)
my saw that im using :)
Thank you, i really appreciate all of the information you guys are givin me
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
 :P to Drew! ;D
He's right though, I shouldn't throw my two cents in without knowing what exactly you wanted.
DrewKaree
  • HAH! Nice one!
:P to Drew! ;D
 :P right back atcha ;)
PICTURES ARE ALWAYS A GOOD IDEA TO GIVE US, EVEN CRAPPY CAMERA PHONE PICS!
Give us a pic, and suggestions and tips can be offered that you never DREAMED of doing with your original design.  Just look at Pixelhugger's cab.  He wanted to get a shelving unit from Wal-Mart, and look what someone talked him into!  ;) ;D ;D
