Author Topic: how do i set up MARS coin mech on mame cab  (Read 2686 times)
grayxx
  • Last login:July 27, 2006, 07:25:32 am
« on: January 07, 2006, 01:33:36 pm »
hi guys ive got a mars 115 coin mech, and im wanting to use it on my cab but havnt got a clue how to do it ive enclosed a pic.
« Last Edit: January 08, 2006, 07:13:47 am by grayxx »
SithMaster
Re: how do i set up coin mech on mame cab
« Reply #1 on: January 07, 2006, 04:52:58 pm »
If you only have the mech you need a door with the mounting parts and the switch.  though you dont really need a door just something to attach the mech to and hold a switch so when the quarter falls through it triggers the switch.  so if you can rig up something like this
and then wire the switch to your encoder and change the input setting in mame to that input for coin input for that player.
grayxx
« Reply #2 on: January 07, 2006, 07:47:55 pm »
i dont think this is a micro switch version of a coin mech  ???
SithMaster
« Reply #3 on: January 07, 2006, 11:46:29 pm »
i must admit im not familar with this type of mech but what about the two metal pieces in the top right corner of your pic?
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
Re: how do i set up MARS coin mech on mame cab
« Reply #4 on: January 08, 2006, 08:47:46 am »
I have a mars coin mech on my cab... I will look at how I have it hooked up in a bit and post back (works perfectly btw)
also configurable for credit settings
grayxx
« Reply #5 on: January 08, 2006, 09:07:49 am »
thanx Jess-- looking farward to it
« Last Edit: January 08, 2006, 09:16:17 am by grayxx »
Jess--
    • My Botched Cab
« Reply #6 on: January 08, 2006, 09:16:40 am »
ok mine is is an MS111 which looks older than the one you have it is wired as follows.
according to the markings on the board (screw terminals on mine)
+12 (hooked up to original cabinets psu)
Gnd connected to original Cab gnd and to Jpac Gnd
Cred goes into Jamma harness but if used on an Ipac would connect to Coin1 input
Lamp Not connected
Mtr connects to my mechanical meter (not required)
My mars system has a cable between the actual coin slot and the board, you may need to make yourself one up as it does not look as if yours is connected in your picture.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: January 08, 2006, 10:59:46 am »
Contact tech support at the manufacturer, www.meiglobal.com
grayxx
« Reply #8 on: January 08, 2006, 03:00:26 pm »
cheers Jess-- good help, but i think that top strip that you have your wires coming out is worded different to mine, i have under my strip SUPPLY with a black and yellow wire, GAME with a green wire, METER with no wires and LAMP with black and yellow/red wire, so how does yours read?????
Jess--
    • My Botched Cab
« Reply #9 on: January 10, 2006, 01:32:34 pm »
supply on yours should be the same as +12v and Gnd on mine
Game = Credit
Meter = mechanical meter (12v pulse output)
Lamp = Lamp outputs (for lighting coinslots)
