Author Topic: Plexi thickness and dremel bit  (Read 3543 times)
zirk
  • Last login:February 05, 2003, 01:28:39 pm
« on: February 05, 2003, 03:29:59 am »
Hi, two small questions.
1) What would be a good size for CP/Marquee/beezel plexi ? I used some 4mm for beezel at another project, but I think its a bit too thick for a CP. Would 2mm be good enough ? (If you have the inch system, no problem. I can convert :)
2) Anyone know of a dremel bit that can be used to make slots for Happ T-molding ?
thanks
« Last Edit: February 05, 2003, 04:11:45 pm by zirk »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Plexi thikness and dremel bit
« Reply #1 on: February 05, 2003, 03:43:02 am »
I have 1/8" plexi on my CP.
I happen to have my TI-85 next to me, time to convert.
3.187mm
« Last Edit: February 05, 2003, 03:44:01 am by SirPoonga »
zirk
« Reply #2 on: February 05, 2003, 04:00:31 am »
Ok, thanks, then I know 3 mm is not too little. Would you say that would be a minimum, or could I try 2 mm ?
TI, never leave home without it :)
SirPoonga
  • Puck'em Up
« Reply #3 on: February 05, 2003, 04:08:34 am »
actually, the thinner you get the better, especially depending on the controls you plan on using.
hyiu
    • www
« Reply #4 on: February 05, 2003, 10:38:08 am »
on the control panel... assuming you have 1/2 in + wood lying beneath... you can just get the thinnest lexan....
(sorry.... I only use lexan cause no cracking when drilling...)
as for dremel..... there is a caribide slot cutting bit that can be used for t_molding....
try this link...
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=201;start=0
« Last Edit: February 05, 2003, 10:40:43 am by hyiu »
eightbit
  • My cab is never done...
« Reply #5 on: February 05, 2003, 11:48:14 am »
Cutting a t-slot with a dremel is going to be tough on the dremel and slow. I'd suggest borrowing or renting a router and you can zip the whole t-slot out in 2 minutes. Of course then more than likely your going to have to also purchase the t-slot bit.
zirk
« Reply #6 on: February 05, 2003, 01:31:19 pm »
"Cutting a t-slot with a dremel is going to be tough on the dremel and slow. "
I reccon :) But thats what I have, and
"I'd suggest borrowing or renting a router and you can zip the whole t-slot out in 2 minutes."
I dont know anyone with a router, and I dont think there are any rentals around :(
"Of course then more than likely your going to have to also purchase the t-slot bit." And the router.
I'll check up on the dremel first. If its a no-good, I hope my friendly hardware store accepts Mastercard :)
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #7 on: February 05, 2003, 01:33:30 pm »
I have 2mm Lexan on my controlpanel, and it works fine. The wood under it is 10mm. (pictures available on my homepage)
eightbit
« Reply #8 on: February 05, 2003, 02:07:16 pm »
Hyiu mentioned that there is a bit for your dremel to cut the slot. There is also an attachment to turn your router into a mini-router. If you already have the dremel this may be a good route to go.
zirk
« Reply #9 on: February 05, 2003, 02:34:19 pm »
Great ! The smaller, the better.
I also got inspired by the LED's :)
Do you draw power from thi I-pac for them ?
-Zirk
Carsten Carlos
« Reply #10 on: February 05, 2003, 02:58:42 pm »
Nope, I just took a 5V/12V-line out from the PC - just get a powerplug indentical to those on the harddisks or CD-Roms and lead it out for all your needs.
I'll also drive a car-amplifier this way with the internal powersupply.
Unfortunately Andy's I-Pac can't draw that much current as needed for high-intensity led's.
There is a really long thread about this stuff somewhere in the forum, try to search!  :) Guess it should reveal with LED button or such words.
zirk
« Reply #11 on: February 05, 2003, 03:13:56 pm »
And If I had remembered what I had just read on your site, I would aready know the answer. Silly me. Too exited, I guess :)
zirk
« Reply #12 on: February 05, 2003, 03:18:43 pm »
"Hyiu mentioned that there is a bit for your dremel to cut the slot"
Found it. Part 542 hunting tomorrow.
"There is also an attachment to turn your router into a mini-router. If you already have the dremel this may be a good route to go"
I have both the dremel and router attachment, so spending 15$ on a bit is far cheaper than buying a router for 200$+ bit for 15$. Then again, I always wanted a router, even if I dont have the slightest idea what I would use it for.
hyiu
    • www
« Reply #13 on: February 05, 2003, 03:22:36 pm »
well... I can tell you... if you like wood working....
router is FUN !!!!!  ;D  ;D  ;D
I got a dremel tool.... and then got a router !!...
I have to say... it is NICE.... more fun than jig saw, circular saw... drill combined.... can do A LOT of cool stuffs... heee hee....
mrhowell
  • Last login:August 01, 2025, 09:42:31 pm
« Reply #14 on: February 05, 2003, 03:24:55 pm »
$200.00 router?
What is that pappy?
zirk
« Reply #15 on: February 05, 2003, 03:29:20 pm »
$200.00 router?
I live in Norway. The cheapest router that can actually rout is about 180$ (for a black and decker) The Boch is another 100$ or so.
eightbit
« Reply #16 on: February 05, 2003, 03:37:56 pm »
$200.00 router?
I have no clue what that works out to in us dollars but we can get a router pretty easy for under $50 in US dollars.
http://www.sears.com/sr/product/summary/productsummary.jsp?BV_SessionID=@@@@1509884569.1044477359@@@@&BV_EngineID=ccidadchhhkjlflcehgcemgdffmdfko.0&vertical=SEARS&fromAuto=YES&bidsite=&pid=00917504000
zirk
« Reply #17 on: February 05, 2003, 04:03:37 pm »
Well, 180$ is about 180 USD ;) Converted from Norwegian Kroner. I'll have another look in the cheaper stores, but no way am I going to find a router for 50 us $ Stuff are a lot more expencive here than in the US.
SirPoonga
  • Puck'em Up
« Reply #18 on: February 05, 2003, 05:45:01 pm »
Really?  I think you under-estimate the dremel:)  I didn't do tmolding, bit I rounded my corners.  The dremel goes through mdf like butter.
