Author Topic: Using smoked plexiglas - Hey RandyT!  (Read 30522 times)
mattudland
  • Last login:September 29, 2012, 08:17:57 am
  • Official Arcade Controls Opera Singer
Re:Using smoked plexiglas - Hey RandyT!
« Reply #40 on: February 12, 2003, 12:16:46 am »
Okay, here is what I have and I hope you can tell what I tried to do...
1st picture:  Monitor without any bezel, glass, notta.  Just inside the cab.
2nd Picture:  Monitor with a black piece of posterboard cut to fit the edge and act as a soft bezel that will follow the curve of the monitor
3rd Picture:  Monitor with black posterboard, as well as the wooden frame that I drill into place with the cabinet.
4th Picture:  Monitor with black posterboard, wooden bezel/frame, and another piece of black posterboard cut to fit the wooden frame.  It has the street fighter decal on it...
5th Picture:  Monitor with black posterboard, wooden frame, black frame number 2, and smoke plexi-glass in place.
That piece of wood they all rest on at the angle, is then covered up by my control panel when it is screwed in place.  Thus, you cannot remove any of the monitor pieces without the CP being taken off.
The smoke-plexi is 1/8th inch, and it does wonders.  It is plenty strong too especially with the wooden brace back there.
If you need any other pics or explanations, let me know!
- Matt
Of course that's just my opinion, I could be wrong.
Ted_Striker
  • Last login:July 18, 2016, 01:28:42 pm
  • Insert Witty Comment Here!
« Reply #41 on: February 12, 2003, 12:30:36 pm »
my cabinet is refurbished.  It had smoked plexi and glass.  both 1/8th thick.  Somebody asked how to support 1/8th plexi... put glass behind it.  My cabinet looks alot like the autocad drawings earlier in the thread.  Just lay it in...   And yes with a happs bezel and my computer monitor case painted black I see nothing inside the cabinet but image... looks nice.  I don't think the pictures above do it justice (although the pictures are quite helpful).  I think smoked plexi works perfect.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #42 on: February 17, 2003, 04:02:00 pm »
Well,
A few people asked about using car/limo tint... being lazy/cheap I grabbed a roll of insta-cling dark tint.
It's basically static cling tint.
Here *was* my thought process.  I currently have glass (1/8" thick)
... and of course when I was in high school ( geez about 10 years ago) I had an aborted attempt at tinting my car windows...  and felt the problem was the cramped space/poor leverage, curves, and trying to line up multiple sheets  (rear window)
... so... a rectangle that was smaller than one sheet width laid out on my kitchen table should be no problem... right? er.... read on...
I coulda used regular application tint, but thought the insta-cling static cling stuff would be easier to manuever.  I also noted that the static cling stuff was a thicker/bigger mil...
Well... long story moderatley long...  I'm glad I measured the glass while it was out ( 22 11/16"  X   23  3/4" for my future reference) so that I can look for  smoke plexi at HD/lowes. =P
It looks "ok" in the spots that don't have bubbles... (I got ticked after my 3rd application of film and said good enough for now)... but not as good as smoke plexi would have...
*Shrug*  just thought I would share my misadventure...
note: if you were reasonably skilled in real tint application it might not be that bad an idea to try it, otherwise just go for the smoke plexi...
rampy
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
Glass or plexi?
« Reply #43 on: February 18, 2003, 04:05:23 am »
I wanna go with smoked glass, too (1/4") - but wonder if I should use real glass or just plexi?
Wouldn't it be better to clean and less sensitive to scratches, maybe even clearer to view as plexi?
I noticed most of the cabs (all?) used plexi, but I guess this was more to avoid getting broken if anyone has lost to often in the game. :)
Last but not least, anyone tried brownish instead of grayish tint?
eightbit
  • My cab is never done...
Re:Glass or plexi?
« Reply #44 on: February 18, 2003, 09:21:52 am »
Glass won't scartch like plexi will. Its tough to put scratches in glass. Plexi is easy to scratch. Glass would also be clearer to view. Plexi is harder to break because it is flexible and its cheaper.
RandyT
    • GroovyGameGear.com
Re:Glass or plexi?
« Reply #45 on: February 18, 2003, 09:36:20 am »
Yes and Yes.  But there are a couple things to consider.  The type of glass with the properties you are looking for is likely to be expensive.
The other thing is that this acrylic material probably lets through about %25 of the light that enters it without a substantial color shift.  Finding glass with these properties could be difficult at best.
You also would probably want to make sure that the glass is tempered for safety reasons.
Haven't tried it, but don't recommend it.  The best case scenario is a material that approximates what is known as a "neutral density filter".  This cuts the frequency of light evenly across the visible spectrum as not to impart changes in color.  The gray material is much closer to having this property than the brown.
RandyT
Carsten Carlos
« Reply #46 on: February 18, 2003, 10:57:41 am »
Guess I'll need an expert here in Germany to find out about this and what to buy. The price isn't that much of a problem (or is it really expensive?), I spend so much time on this cab that I want it to be as good as it can!
Tempered glass is this security glass that doesn't break in sharp pieces, right? Well, you never know, although I wonder if this is availabe as gray smoked. :-[
« Last Edit: February 18, 2003, 10:58:30 am by Carsten Carlos »
The Man
  • Last login:August 27, 2009, 03:41:49 pm
  • I'm easy like Sunday mornin!
Re:Glass or plexi?
« Reply #47 on: February 18, 2003, 02:15:30 pm »
My DigDug cocktail plexi is more brown than gray and it looks great.
TM
Carsten Carlos
« Reply #48 on: February 21, 2003, 10:57:55 am »
Mine is 1/8" thick, but is very well supported.  I have it sitting on a shelf, runners going full length both sides, and it is kept from moving because it is trapped behind the marquee speaker board and the rear of the control panel.  I have a Happ bezel behind it, so that also adds extra support.
This method of installing the front glass seems to be common on arcade machines, and the best part is that you don't need to mess with any tools or hardware to remove it.  Flip up the control panel and you can have the plexi and bezel off in seconds.  Here are a couple of screen grabs from my cad file to show what I'm talking about (the pink in the first shot is the plexi).
You can see the plexi supports in some of the photos here:  http://www.oscarcontrols.com/unnamed/.
What I wonder (and this is my current problem on my cab) what do you do with the small gap between the glas and the panel? I'm still searching for a good solution that I still can easy change panels, have no gap, and can put the glass as near to the panel as possible.
« Last Edit: February 21, 2003, 10:58:42 am by Carsten Carlos »
OSCAR
    • Oscar Controls
« Reply #49 on: February 22, 2003, 01:40:31 am »
Heh, sure Carsten, go ahead and point out my short-cut...  :)
The gap isn't very noticable when you have a black control panel and black bezel, but here is the "proper" way to do it:
There is a retainer that should go on the back of the control panel.  To do this correctly, your front glass should stop just above the back edge of your control panel so the retainer lays flat against the glass.  On my cab I didn't want to fabricate a retainer (read as "lazy" :) ) so I moved the glass ledge beyond the control panel so the rear of the control would lay up against the glass.
To replicate the original design faithfully, you would have to make fairly accurate cuts and bend the retainer to the correct angle as to not put too much pressure against the glass.  If the angle on the retainer is too shallow, you would still have a gap...  I chose to avoid the trial and error process on my project, but if you have the means and skill to do this correctly, then it would be well worth it!
Here are a couple of shots of my converted Main Event cab.
Dr. J
  • Last login:November 26, 2004, 05:53:01 pm
    • DrJsArcade Cabinet
« Reply #50 on: February 23, 2003, 10:54:23 pm »
That's cool.  Can you show us a pic of the smoked glass with the room lights on.  Does it look tinted?  8)
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #51 on: February 24, 2003, 12:19:42 am »
My Star Wars Cockpit has 1/4" thick glass.  Very brown looking and it works great.  Of course it's a vector game, don't know if that makes a dif.
Carsten Carlos
« Reply #52 on: February 24, 2003, 02:11:40 am »
Thanx, Oscar, that pictures did really help! (as usual  :D)
I found something similar at the local hardwareshop - but made of rubber. If it should work, I'll post it here!
rampy
  • *shrug*
« Reply #53 on: March 01, 2003, 10:13:02 pm »
Hey all,
Just wanted to say that I picked up some 1/8" smoke/tinted plexi (31 beans cut to size - from a local glass store/company)...
it really made a huge difference in the over all look and presentation of my cab... it hides the bezel and monitor mounts etc beautifully...  and it does make the vertical games look a little better on my horizontal 21" PC monitor
thanks to oscar and randyT for  pointing out this technique.
I took some digital pics but not sure if they're really good representations cuz i'm lousy w/my camera.. *shrug*
Is there arny tips for adjusting brightness/contrast and colors for maximum effect? Bueller?
Rampy
SNAAAKE
  • -Banned-
« Reply #54 on: March 02, 2003, 12:54:28 am »
Rampy
yeah..dont resize more then once and jack up the contrast and brightness a little...post some pictures will ya?I am thinking about this for a while now.i hear it make the screen look little better.didnt have any luck finding this tinted plexi.
rampy
  • *shrug*
« Reply #55 on: March 02, 2003, 12:25:42 pm »
Rampy
Snaaake, I *know* how to resize digital images - it would also make my picture comparison invalid...
Sorry if I wasn't clear.
What I was (am still) asking for is suggestions on how to adjust the MONITORS b and c for maximum effect with the smoked plexi...  *shrug*
Rampy
SNAAAKE
  • -Banned-
« Reply #56 on: March 02, 2003, 12:41:03 pm »
LOL !..allright..sorry for that..
I pulled a "Howard_Casto" on you ! :D
someone else have to help you on this..have no idea myself..never used this kind of plexi..never even seen em..well car windows but thats it.. ;D
« Last Edit: June 26, 2003, 09:46:14 pm by SNAAAKE »
canardo
  • Last login:January 01, 2008, 07:32:23 am
« Reply #57 on: March 04, 2003, 03:49:28 pm »
did anyone find any other sources to purchase this stuff
Ghoul
  • Last login:September 15, 2004, 08:59:06 am
  • Karate Fish Master
« Reply #58 on: March 04, 2003, 06:05:59 pm »
No major stores in my area carried it. However, I did find several smaller businesses that carried lots of different tints and would cut to any size for a $5 fee. I think your best bet is to ask around at the larger chains in your area about where you might find it and then hit the phone books, I spent about 40 minutes on the phone and ended up with 5 different stores that all carry what I am looking for and are reasonably priced.
Justin
  • Last login:January 08, 2026, 10:28:19 pm
    • Centipede MAME cabinet
« Reply #59 on: June 24, 2003, 11:54:26 pm »
OK, so I'm convinced I need tinted plexi.
now, can someone tell me what percentage of darkness to use?  Just asking for 'tinted plexi' might not be enough.    Wouldn't want something that would harldy let any light through!
I'm figuring this is like 50% dark?  or am I speaking out of my arse?  ???
"3 warps to Uranus" -- so I stopped playing!
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #60 on: June 25, 2003, 12:20:20 am »
I know what you mean.  I, too, want something that's dark enough to cover up the bezel and any gaps that might be showing, but to also let vibrant colours through from the monitor.  Anyone have any ideas for me and Justin?  :)
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
rampy
  • *shrug*
« Reply #61 on: June 25, 2003, 10:27:31 am »
Odonadon
Well I'm not sure you can have BOTH necessarily... I mean if you get decent quality smoked plexi that doesn't color shift dramatically the colors will be similiar but kinda the idea is to "tighten up" the colors a bit (see oscars original pics on first page).
I'm sure you can get lighter smoked plexi for a less dramatic effect....
I know Oscar and myself didn't have the light transmission ratings available when picking out our respective smoked plexi pieces.  The glass store who ordered my piece was much more general.  They needed to know thickness (1/8th inch in my case)... material (plexi)... and what color (brown versus grey).  If there were ranges available they didn't offer them to me, I'm guessing I got the "medium" range of smoked grey plexi.
*shrug*
rampy
MilitiaMan
  • Last login:May 28, 2011, 09:25:35 am
  • It's a fine line between hobby and mental illness.
« Reply #62 on: June 25, 2003, 02:04:48 pm »
I just put a peice of tinted plexi (1/8 inch) on my MAME cab and it looks great. I did have to adjust the monitor brightness a bit, but after doing so everything looked so much better.
I bought mine at Lowes. It was like 20 bucks for a 24" x 48"  sheet and they even cut it to the size I needed.
When I had the clear plexi on, I could see very clearly that there was a black bezel covering up a spraypainted monitor case. It looked a bit "amateurish" if you ask me. The good news = the new smoked plexi makes the monitor case and the black bezel completely indistinguishable. A 500 percent improvement.
BTW, In case it matters, this particulary plexi I bought has the brand name Lucite and is tinted bronze, not grey --- looks great, though.
Can post pics if you so desire ... LMK.
MM
Lilwolf
« Reply #63 on: June 25, 2003, 02:05:09 pm »
Sad thing...
I just bought a true happs bezel for my EYGO 27" monitor... but no my next project, I think I'm going for a smoked Plexi after this thread...  Shipping was REALLY expensive!
So the question is.  Is there any good smoked plexi that will work well UNDER another piece of glass?  And how do I attach it?
I already have the glass for my cocktail table, so it will also have to hold horizontally.
Odonadon
    • Turbo2k
« Reply #64 on: June 25, 2003, 11:27:33 pm »
Please do.
Odonadon
RandyT
« Reply #65 on: June 26, 2003, 09:38:45 pm »
For anyone who is wondering:
My experience has shown there to be 4 varieties (more if you count thickness, but I'm not :) ).
Bronze or Gray, light or dark.  Those are the options.  If you have the luxury of selecting what you want, I recommend Gray, dark.
BTW, I haven't tested it with a transmission meter, but I'd be surprised if it were over 30%.
RandyT
Stingray
« Reply #66 on: January 09, 2004, 11:13:13 am »
Thanks to Rampy for pointing this thread out in another related thread. I'm only posting in it to bring it back to the top. I think a lot of the new guys like myself who are just building a cab could benefit from reading through this one. I belive I'm sold on using tinted plexi in mine.
-S
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #67 on: August 26, 2004, 07:08:51 am »
i assume grey tinted glass will give same result as smoked plexy - thats what i've just ordered for my cocktail cab.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #68 on: August 26, 2004, 07:36:51 am »
I see you brought this dinosaur back to life too  ;D
Glass is better than plexi though. Otherwise people would use plexi in their windows.
RandyT
« Reply #69 on: August 26, 2004, 07:53:14 am »
Glass is better than plexi for a cocktail.  It doesn't scratch and it's just an overall better surface for a table.  Make sure it's tempered though.
For a cabinet, it doesn't really matter.  Good luck finding the tint talked about in this thread in glass though.  If you do, you can bet it will cost 5-10X more than the plexi (I work in the glass industry).
And some do use plexi in their "windows", it depends on the application.
RandyT
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
« Reply #70 on: August 27, 2004, 03:22:41 am »
What is the difference in tint between glass and plexi?  Would the glass tint be lighter, darker, or a different color.  I was all set on glass but might have to change that.  I was quoted $33 for 1/4" thick so I'm guessing this would be the wrong type?
gprime
  • Last login:November 02, 2024, 01:23:19 pm
  • still the newb
    • G-Prime .NET
« Reply #71 on: August 27, 2004, 04:04:36 am »
This makes so much of a difference. I used mine with a clear piece of plexi for the longest time, and then recently I got a nice piece of smoked plexi. It's easier on the eyes, and for some reason things just look better. And too, I botched my make-it-at-home-bezel, which is covered up nicely behind the plexi.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #72 on: August 27, 2004, 04:22:52 am »
The tint is the same (or at least you can order it to be the same). Glass just looks a lot better. You can get away with plexi if you don't have much money to spend, but who cares about a few bucks.
darktemp
  • Rumbler
« Reply #73 on: August 27, 2004, 06:23:33 am »
That's what I would have thought, but RandyT clearly knows his stuff on the subject.  Just looking for clarification on his statement above.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #74 on: August 27, 2004, 07:03:08 am »
Randy "works" in every business that comes up here. Just go to a shop and compare them yourself. Glass looks better but costs more. Plexi works ok too, but looks less nice (for tinted plexi it's less difference than for clear plexi, but still) and will deteriorate quicker over time.
So both work, but it depends on your importance on the looks issue if it's worth it. I don't think anyone else can decide that for you.
RandyT
« Reply #75 on: August 27, 2004, 08:13:42 am »
Patrick,
Are you naturally a jerk or did the bullies at your high school turn you into one after years of systematic pummeling?
I've been in the precision optics business for the last 13 years and now design and build "glasses-free" 3D optical systems, many of which are currently being built into interactive kiosks.  My name is on 3 patents related to such. We also have a company that wants these systems built into arcade machines.  So yes, much of what gets discussed here are things I deal with every day in a professional capacity.  What does your resume look like?
To answer the other poster's question, the cost difference would be based on the rarity of the material, as well as any tempering that might need to be done for safety reasons.  You can't cut tempered glass (at least not in the conventional way), so tempering must be done after it is cut to size.  And, the very dark tint (in glass) has little demand, therefore the production batches are smaller and the prices are higher.
The plexi transmits roughly 18% of the light from the monitor.  Check the transmission of the glass you are considering, or ask for the specifications, they are usually available.  Over 25% transmission, and you will start to see the outline of the monitor, which will spoil the effect when a vertical game is displayed on a horizontal monitor.
33$ isn't a bad price, but you should check on the transmission specs and, especially if you have kids, the tempering.
RandyT
BTW, whoever resurrected this one, thanks.  I actually have tested the transmission since this one was last active and forgot to update it with my findings. The real numbers are in this post. Oh, and the plexi appears to be formulated in such a way that the transmission doesn't vary much whether it is 1/8 or 1/4 in. thick.  They are both pretty much the same.
« Last Edit: August 27, 2004, 09:34:38 am by RandyT »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #76 on: August 27, 2004, 09:49:15 am »
Patrick,
He,he, no, but are you that insecure that you need to claim "I have been in this business for x years" on just about every subject. If I add them all up you should probably be 100 years old now, but more importantly "precision optics" is quite a bit away from the "glass industry" or comparing smoked plexi vs glass.
My resume is simply that I compared the two side by side and I saw that smoked glass looks much better (apart from the advice to buy glass from people who actually ARE in the glass/plexi industry). Indeed it was more expensive and it had to be made by order, but that does not negate that it looks better. Also I always notice a substantial amount of scratches on plexi.
There is a difference, but it's up to people to decide for themselves if it's worth the extra cost.
I'm really surprised so many people choose smoked plexi over smoked tempered glass (on upright cabs). I think the only one outspoken about using glass would be paigeoliver. But then, he can get it pretty cheap.
darktemp
  • Rumbler
« Reply #77 on: August 27, 2004, 11:01:55 am »
Thanks RandyT, that's exactly what I was looking for.  I should have mentioned that the $33 was for "tinted and tempered glass", maybe I should have asked for smoked but I would think it's the same thing.  I'll ask for the light rating today, Thanks again. :)
RandyT
« Reply #78 on: August 27, 2004, 12:13:44 pm »
One can't create and or design precision optics without knowing about the materials one would use to do so.  That would be like a carpenter not having any knowledge of the woods he uses.
I made that statement because, in public forums like this one, there are often individuals (like yourself) who make comments about things they have little to no experience with, in attempt to make themselves appear to be more intelligent than they actually are, often resulting in disservice to people looking for help by leading them down incorrect paths.  In your specific instance, this happens as a side effect of what appears to be a personal feud with me or anything with my name on it.
Here's the deal.  I own and am proficient with virtually every piece of hardware used in the creation of an arcade machine.  I personally own (2) 36" printers, a 40" vinyl cutter, a 4'x8' CNC router table, a complete electronics assembly station, etc. , etc.....    I write software, design electronics, cabinetry and kiosks.  All of these things I seem to do well enough that people keep paying me (well) to do them.  Should I apologize for trying to help people through my considerable experience in this field?  It doesn't mean that my opinions are more valid than any one elses, but I can certainly identify BS when I see it.
So in other words, just more of the same subjective commentary this board has come to expect from your posts.  I was hoping you actually had a frame of reference on this one and not just "the guy at the glass shop told me so, and the context of the discussion isn't important."
After years of abuse in a commercial environment, glass will look better.  In your living room, it just won't matter.
This thread pertained to a specific effect that could be achieved using a specific material with certain specifications.  You won't find glass like this "off the shelf", if you can find it at all.  The closest inexpensive glass material like this is "architectural glass" for environmental management.  This glass has a coating that reflects more light on both sides of the material than uncoated stock, which is undesireable in an arcade machine unless you like looking at an image of yourself superimposed over the game you are playing (then again, you'd probably enjoy that).
But as usual, you've convoluted a thread full of good, simple advice by adding uncertainty and criticism about something you appear not to fully understand.
Well done.
RandyT
Darktemp:  PM me if you have any questions.  I think this thread is starting to go downhill fast :) .
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
« Reply #79 on: August 27, 2004, 12:37:07 pm »
Hmm, I might have to give this a shot myself...  Replace the glass in my Showcase with some smoked plexi, see how it works for an S-Video TV instead of an arcade monitor...  :)
One question is will it interfere with the IR signal of the remote?  Only time will tell...
Holy crap!  I hadn't thought of that.  I'm just about to start my cabinet and am planning on using a ~25" TV w/S-Video input.  I really hadn't thought about how I was going to turn that thing on.  Now've I've got some planning to do.  I don't want to have to keep track of a remote.  SHAZBOT!
dot
