Author Topic: CP materials/thickness  (Read 3020 times)
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
« on: February 04, 2003, 04:57:20 pm »
It seems like 3/4 plywood/mdf/whatever is generally used for building CPs. I notice a lot of folks use 3/4, add plexi or lexan and end up routing 1/4 inch of wood from the inside of the panel to adjust the joystick height. Is there any reason why 1/2 wood + 1/4 plexi/lexan isn't used to begin with? Is 1/2 wood not sturdy enough? I have both 1/2 + 3/4 but I'm not sure which to use.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:CP materials/thickness
« Reply #1 on: February 04, 2003, 05:58:48 pm »
usually because you buy mdf in 4'x8' sheets:)   Using vailable material.  I wouldn't buy a sheet JUST for the cp since that;s too much wood.
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #2 on: February 06, 2003, 03:12:42 pm »
hehe....that is exactly what i did last night SirP!   ;D
bought myself a 4x8 sheet of 5/8 mdf just for the CP.
some of it will probably go towards a shelf for my DC inside, and the rest of it - ???  i will probably use some of the extras for "test" CPs.   ::)
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
« Reply #3 on: February 06, 2003, 04:08:32 pm »
My Home Depot here in PA has 1/2" MDF 2' by 4' for under $5...perfect for a cp or two
Now witness the power of this FULLY OPERATIONAL Mame machine!
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #4 on: February 06, 2003, 04:22:05 pm »
what if you are building a 4 player CP? :)
SirPoonga
  • Puck'em Up
« Reply #5 on: February 06, 2003, 06:35:10 pm »
4'x8' is alot of wood.  I can build two subwoofer enclosers with that.
Silverwind
« Reply #6 on: February 06, 2003, 07:22:38 pm »
well.. some enclosures can get pretty large.. maybe two small ones.. if your talking a 5cu vented enclosure...
the CP I made might be overly large.. not sure yet..  I made it four player.. and spaced them out enough for it to be comfortable..
it is basically half an octagon more or less.. 48" across the top..  ~30" across the bottom..  so just for the top and bottom of my CP it was almost a half sheet... now what about the sides? clearly I need to use the other half sheet?
 ________
 \_______/
basically looks like that
« Last Edit: February 06, 2003, 07:24:25 pm by Silverwind »
