Author Topic: switching PS question and amps  (Read 824 times)
unix4hire
  • Last login:October 16, 2008, 06:12:47 pm
  • activate interlocks...
    • My Business
« on: December 16, 2005, 09:20:03 pm »
I was about to swap out a power supply in a cabinet (something new to me) and noticed that one of the connections on the old is labled 12V+ 2A, while on the new PS I pulled from another machine it's labled 12V+ 3A.  All the other connectors are the same label.  So, will the 3A one work?  My thinking (hopefully) is that it doesnt' actually push 3A all the time but will allow consumption of 3A if necessary.  If that's the case then I can replace the 2A with the 3A connection.  Howeve,r I dont know if it does in fact push 3A or 2A, and I certainly don't want to ruin something!  so, will this PS (otherwise identical to old one, peter chou, etc) work as a replacement?  thx
---Erich
Ed_McCarron
Re: switching PS question and amps
« Reply #1 on: December 16, 2005, 09:54:23 pm »
Yes.
Replacing a 2A power supply with a 3A power supply is fine.
It may be overkill, but will do no harm.
Do make sure the voltages are in the right places on the connector, tho.
A PS won't 'push' anything, it will only supply what is 'pulled'. :)
