Author Topic: Cutting my NES chaff.  (Read 3601 times)
Franco
« on: December 14, 2005, 06:06:01 am »
Im looking to do a DC NES mod soon and I thought I would sort a set of NES roms out for use with NesterDC SE.
I looked in my NES rom folder and there is over 8000 roms taking up over 1.8GB. Obviously alot of them are regional (for want of a better word) repeats ie (J), (U), (E) and I only want one copy of each rom, probably (U). There are also different versions of each 'regional' rom.  I was wondering if there is a program or a method I could use to get my collection down to size?
Thanks.
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
Re: Cutting my NES chaff.
« Reply #1 on: December 14, 2005, 07:19:21 am »
Some one around here made a program for just that. I can't remember the thread it was on right now.
KDOG
« Reply #2 on: December 14, 2005, 07:27:21 am »
Franco
« Reply #3 on: December 14, 2005, 11:37:00 am »
Thanks for the link. I did try searching but I could not seem to find anything.
Ill give this a go later on.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: December 14, 2005, 12:58:39 pm »
Use Good Tools.  It will break it into countries, hacks, etc.....
Here is the link on how to use it and there you will find the link to the program:
http://www.mameworld.net/easyemu/gtguide.htm
Franco
« Reply #5 on: December 14, 2005, 01:37:41 pm »
Thanks, my collection has already been diagnosed with GoodNES and so they are already labeled (U) [!] etc.
I just want to get rid of the (J)'s, (E)'s etc. Can GoodNES do this? If not I will try the method in KDOG's link.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #6 on: December 14, 2005, 01:44:57 pm »
I actually went through mine by hand.  it took about 2 hours, but I have zero games that I don't want and half are just in there because someone "might" play them.  I find that I stick with around 10 games, the rest are just for coolness factor.  With friends using my machine, it makes a difference having things in smaller lists.  If there are 3000 games in your list (in my experience) their eyes glaze over and they ask "Do you have game x?" or just become disinterested.
Have fun.  =)
pointdablame
« Reply #7 on: December 14, 2005, 04:16:09 pm »
you could also do it really easily in the dos prompt by just using the command "del *xx*.zip"  where "xx" is the region/hack (such as (E), or [!] ).  And of course, if your files aren't in .zip files, just change the extension.
You can get rid of all of the (E), (J), and [!] this way in about 30 seconds.
first off your and idiot
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #8 on: December 14, 2005, 05:31:55 pm »
Good Tools definitely will split the roms into individual folders.  It is very easy to do and is one of the first things described in the how to. ;)
duffjr
  • Last login:January 19, 2012, 05:50:14 pm
  • There is no dinosaur name ending in PUSS.
« Reply #9 on: December 15, 2005, 07:14:16 am »
goodtools f-ed me over by renaming all my roms, which i need for zsnes netplay.  i thought it would eliminate the ones with the same checksum, not the same region.
Chemixtry
  • Last login:January 22, 2021, 07:58:17 pm
  • If an experiment works, something has gone wrong
« Reply #10 on: December 15, 2005, 01:41:27 pm »
I used this program made by a fellow byoacer and it worked great. You assign a point value to codes such as region, hack, demo etc and it will filter everything into a new folder. If you are happy with it you just use the new folder. It doesnt change the name of anything.  I sorted mine to only include japanese games if there was not an american version of the game. It made a huge diffence in the amount of space for my snes, nes, and sega collections.
Thread:
http://forum.arcadecontrols.com/index.php?topic=41174.0
Utility:
http://pages.sbcglobal.net/kobe/ROMSorter.zip
Experience is directly proportional to equipment ruined
Necro
  • Last login:December 31, 2025, 03:36:17 pm
« Reply #11 on: December 16, 2005, 10:19:38 am »
I second the ROMsorter program above.
I had issues with it with certain sets (Atari5200 and Atari 7800) because of the presence of [o#] and [b#] and no [!]'s (This is the standard goodset too...they just aren't there).  Those sets are so small though that it was easy to delete the crapola manually.
And, in the end, if you accidentally delete 5-10 of 2000 roms...your not going to notice unless it's a game you normally play.
I kind of wish MAMEwah had a one button 'add to favorites' method that would work well.  Make it easier to setup custom lists.
Franco
« Reply #12 on: December 16, 2005, 11:21:15 am »
Thanks for all the suggestions guys.
Another member uploaded the whole (U) + (E) set to a free download site for me. I may use these methods for my other sets tho.
If anyone else wants the set the DL link should be valid for the next 30days or so. If you want the link PM me, im not going to post it here. Unless this is all against the rules? If so I will edit it out.
Necro
« Reply #13 on: December 16, 2005, 03:05:46 pm »
Just a little note on the ROMSorter program.  If you want to get it to select roms with no tags instead of those with [a#] and [o#], just set a and o as negative values in the options and it will work that way.  At least, it is for me :)
