Author Topic: .187 Quick Disconnects Question  (Read 1286 times)
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« on: December 10, 2005, 07:47:48 pm »
Hey Guys, time for the uber newb of the year question.
How the hell do you use .187 Quick Disconnects?
As in, you cut the wire, do you just slide it in and then clamp the middle and end with pliers to tighten it? Cause i can get the wire in, but i cant close it to keep the wire stuck there..
this is embarassing, but can someone give me some help!  :'(
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
Scott84
Re: .187 Quick Disconnects Question
« Reply #1 on: December 10, 2005, 08:00:01 pm »
Its so damn hard to close it... i know this is simple.
I have to cut a wire on my cp, and put a new button...
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #2 on: December 10, 2005, 08:05:30 pm »
Are you using Crimpers?
« Last Edit: December 10, 2005, 09:26:59 pm by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
Scott84
« Reply #3 on: December 10, 2005, 08:06:34 pm »
So i should use the crimper to 'smush' the QD to close in on the wire?
gotta love my smush language.
Jabba
  • D-Hutt
« Reply #4 on: December 10, 2005, 08:08:10 pm »
Yeah, in the middle of the QD. Don't flatten it, kinda "cut" it till the QD holds...
Scott84
« Reply #5 on: December 10, 2005, 08:10:13 pm »
I jus tried it, it it cuts through the plastic and almost goes right through the metal piece.
the simple things always go wrong with me!
Scott84
« Reply #6 on: December 10, 2005, 08:10:33 pm »
How hard are you pressing? hard? till your hand hurts?
Jabba
  • D-Hutt
« Reply #7 on: December 10, 2005, 08:16:27 pm »
Depends how strong you are. Can you take a picure and upload what you're using to crimp? Shouldn't be that hard! Squeeze until the QD holds, not much more I can tell ya Scott...
Scott84
« Reply #8 on: December 10, 2005, 08:18:27 pm »
I cant take a picture.
When your squeezing the center of the QD its plastic-y and the end where the wire goes in makes the hole bigger and looser.
I need a tutorial of someone doing it in person or in a video.
Its alright, thanks for your help. i appreciate it.
Scott84
« Reply #9 on: December 10, 2005, 08:43:40 pm »
My dad gave me his crimper and it had a 'insul closer'
i got it working 100%
thanks for your help JABBA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1  ;D
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: December 10, 2005, 09:25:16 pm »
http://spystyle.arcadecontrols.com/index8.htm
For anyone else that stumbles across the thread.
Jabba
  • D-Hutt
« Reply #11 on: December 10, 2005, 09:42:12 pm »
