Author Topic: wire connectors  (Read 1070 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
wire connectors
« on: December 03, 2005, 03:35:31 pm »
Hey all,
I am gonna connect a p360 to my ipaq board now that I know where to connect the ground and 5v wires.
My question is what kind of connector do I use to connect the wire to the pins?
It must be a pretty small connector!!
deadmoney5
Re: wire connectors
« Reply #1 on: December 03, 2005, 04:08:45 pm »
and since I am already using the ground pin for the illuminated trackball, I assume I can just splice the ground from the P360 into the same pin connector?
markrvp
  • NFL Expert
Re: wire connectors
« Reply #2 on: December 03, 2005, 08:33:16 pm »
The pin header on the Ipac uses .100 pin spacing - the same as the pinout on an IDE cable and the same as the pin headers on your motherboard that you connect the power & reset switches to.
An easy solution to use is a spare CD-Rom internal audio cable.  The connector on that is the correct spacing.
