Author Topic: Bubble Bobble Stand Alone Marquee Box  (Read 3669 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: November 22, 2005, 05:21:04 pm »
Here's something I made for the heck of it.  I don't even have a place to put it.  I just made it to temporarily store a marquee and a florescent light fixture.
I didn't have my camera handy during construction so I will explain it briefly.
I made this thing in about 1.5 days.  First I cut two identical pieces for the top and bottom out of 5/8" MDF then I cut mounting blocks out of 1.5" x 1.5" stock.  I screwed the MDF onto the blocks, one at each end and immediately puttied the holes.
Then I cut one square out of MDF and then used my jigsaw to round out the corners.  Once the piece looked the way I wanted (with a little sanding) I put it on top of another piece of MDF and used my flush trim bit on my router to make an exact copy.  I use this method frequently for making perfect matching end pieces.  It just makes it so perfect and easy.
While I had my router out I slapped on a slot cutting bit and ran it around these new pieces.
Then I screwed (countersunk again) through these new end pieces into the blocks mounted on the top and bottom pieces.  Wood putty over those holes and then I started priming everything.  I used a Kilz water based primer and it works great.
Then two coats of black with sanding in the middle.  I mounted the light fixture next.  If I had planned this properly, I would have drilled for the mounting screws prior to assembling the box but oh well.
I had purchased some marquee retainers from happ along time ago.  I put these on my table saw with an 80 tooth blade and the cut was factory smooth.
I didn
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Bubble Bobble Stand Alone Marquee Box
« Reply #1 on: November 22, 2005, 05:24:06 pm »
Here's a frontal view
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« Reply #2 on: November 22, 2005, 05:25:12 pm »
Very cool. The t molding is a nice touch.
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #3 on: November 22, 2005, 05:27:24 pm »
NICE!
I have seen a few people do this.
Your's seems real authentic and stuff with the t-moulding.
Nice finish.
I wish I had a game room or bar, I'd bee making a bunch of them!
I have a sports room, maybe I could make some featuring each team...Hmmmmmm.
Half of the people you meet are below average.
Knievel
    • Knievel Kustoms
« Reply #4 on: November 22, 2005, 05:38:44 pm »
Really nice job! Be forewarned I WILL be stealing the t-mold idea.
arcadefever
  • Miami Beach Florida
« Reply #5 on: November 22, 2005, 05:54:35 pm »
really nice, this is one of the best game ever !!!!!
Q*Bert_OP
  • Oh yes, we did!
« Reply #6 on: November 23, 2005, 12:17:24 am »
Nice!!!
