Author Topic: Wanted: Empty cab to buy or borrow  (Read 2075 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: November 14, 2005, 09:35:44 pm »
I need to see if I can fit a standard size cabinet down my basement steps. Does anyone have a 19" monitor cab, empty, that I can either borrow or buy, so I can see if I can fit in down the stairs. I know not all are the same size, but if someone has a centipede, or pacman, or even a crappy JAMMA cab, empty, thanks
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Wanted: Empty cab to buy or borrow
« Reply #1 on: November 14, 2005, 10:40:51 pm »
My best advice is to build a mock-up out of cardboard -- the measurements for a bunch of 19" cabs are available at jakobud's site and will be easier to work the details of any turns you have to make. And it won't mark-up your walls.
I'm not sure that I would expect too many people to lend you a classic cabinet that could apparently get jammed in your stairway.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
srabelpawz
  • Last login:May 16, 2010, 11:07:44 am
« Reply #2 on: November 15, 2005, 12:28:26 am »
« Last Edit: November 15, 2005, 12:53:25 am by srabelpawz »
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: November 15, 2005, 08:27:01 am »
How am I gonna get it on your ship?  Are you going to beam it up?  Couldn't you just beam it into the basement?   Where is your ship located?  Do you really want to borrow a heavy cabinet to see if the dimensions fit?  So many questions, so few answers(i.e. where you're located maybe?).
srabelpawz
« Reply #4 on: November 15, 2005, 09:05:24 am »
  he is in new jersey
USSEnterprise
    • USS Odyssey
« Reply #5 on: November 15, 2005, 10:38:40 am »
Like I said. I'm lookin for a totally empty cab. And yes, I am in NJ. I would consider the cardboard, but cardboard flexes and bends. The particle board on a cab should not
srabelpawz
« Reply #6 on: November 15, 2005, 10:43:09 am »
  my offer still stands ;D
CheffoJeffo
« Reply #7 on: November 15, 2005, 10:59:03 am »
You're not going to be twisting and bending the cardboard mockup (and, really, it isn't hard to build a mockup that is sufficiently rigid)  -- if it is that tight, then you need to start being specific about the size and shape -- just testing any cab with a 19" monitor wouldn't be good enough (e.g. my Asteroids was harder to move in than my 25" MVS cabinet).
Hope it works out for you.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #8 on: November 15, 2005, 11:50:43 am »
Sorry to leave a bad reply.  I think unproductive replies are unnecessary in the BST forum.  Just thought it was an odd request without any info.  I agree about the cardboard box idea to save money.  You could buy boxes from staples or some other shipping place and spend less then ten dollars.  Of course replicating the weight would be hard, but using cardboard, you could make an object larger than what you actually need and it would be easy to maneuver.  So again, sorry for the reply, it was meant to be funny.
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #9 on: November 15, 2005, 08:51:10 pm »
Do you have a washer and dryer in your basement?
Measure their footprint.  If the cabinet footprint is smaller, then it will fit.  A cabinet is no taller than a person, so if you can walk down the stairs without ducking then the cabinet will fit.  If you have to duck on your stairs, put the cabinet on a dolly and tilt it back and it will fit.
I've moved several friends and worked for a moving company.  You don't have to stard worrying about fitting something down the stairs until it's dimensions are significantly larger than the volume a person takes up.
There are a few exceptions.  Extremely old houses, servant stairs,  bla bla bla.   but generally your average set of stairs will take quite a large piece of equipment.
moving washing machines is the damn worst.  If there's a washer in your basement, I wouldn't even worry.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #10 on: November 16, 2005, 08:47:54 am »
I've got a 19" cab (it's a Reactor cab, so it's a it shorter than a "standard" cab) I'm selling.  I'm near DC, so it'd be a day trip to come down and get it, but it's got a good small footrpint (30"x30", IIRC)
http://forum.arcadecontrols.com/index.php?topic=44875.0
If no one feeds the trolls, we're just going to keep eating your goats.
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
« Reply #11 on: November 16, 2005, 09:31:18 am »
If you can get a fridge downstairs then its safe to say you can get a dynamo cab down your stairs... measure the biggest appliance/furnitutre you got down the stairs and compare the measurements to an arcade machines measurements.
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
LPZ
  • Last login:April 11, 2015, 01:55:21 pm
  • 2nd place is the first loser!
« Reply #12 on: November 16, 2005, 10:30:38 am »
Quote from: Mark70 link=topic=45815.msg437890#msg437890 date=113210587
[quote
I just bought a new washing machine, double the capacity of my old one and it was just about half of the weight.  It's the old ones you have to worry about.  Technology is an amazing thing!
LPZ
Dual 50 Caliber Continuous Fire Leon Type Machine Guns......OH YEAH!!!!!
USSEnterprise
    • USS Odyssey
« Reply #13 on: November 16, 2005, 10:50:45 am »
No appliances in the basement. I'll just try with the cardboard for now
