Author Topic: how do i get rid of the bios screens on startup  (Read 3775 times)
grayxx
  • Last login:July 27, 2006, 07:25:32 am
« on: November 06, 2005, 02:50:29 pm »
hi guys how do i get rid of the info bios whatever screens that come up when you start up your pc, it tells you what memory etc?? all help much appreciated.....
koolmoecraig
    • My Intervention
Re: how do i get rid of the bios screens on startup
« Reply #1 on: November 06, 2005, 03:38:22 pm »
You don't.
I could be wrong but you can only do that if your motherboard manufacturer has built in the ability to do so. Otherwise, just set up your cabinet to power on the monitor about 15 secs after the computer starts.
grayxx
« Reply #2 on: November 06, 2005, 03:59:54 pm »
thanx for the reply koolmoecraig, how do i get my monitor to power up 15 seconds after the computer starts??
SirPeale
  • Green Mountain Man
« Reply #3 on: November 06, 2005, 05:03:41 pm »
A complicated remedy involving timers and relays.
And why bother?  I was of the mind for a while to do the same thing, but a lot of recent machines actually run off x86 architechture.  BIOS screens are normal for their boot sequence.  Once they're passed, it's nothing big.
Abomination
  • Last login:December 07, 2023, 11:18:15 am
« Reply #4 on: November 06, 2005, 10:33:18 pm »
I'm sure he is like me, he doesnt want people automaticly knowing its a PC in a really big box  ;D.
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #5 on: November 06, 2005, 11:26:13 pm »
On a related question, how do I get rid of my manufacturer's splashscreen on startup? I want to see the POST
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
Abomination
« Reply #6 on: November 06, 2005, 11:37:15 pm »
These questions are almost unanswerable because its different for every single motherboard, its even different amongst the same manufacture, unless its in your manufacturers bios options its not possible, some boards like ASUS give you a skin option, otherwise the start-up screen logo is flashed onto the bios.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #7 on: November 07, 2005, 12:04:35 am »
Thumb around bios for "splash screen"
BobA
  • What Me Worry?
« Reply #8 on: November 07, 2005, 12:40:46 am »
Some PCs lock the bios with a jumper on the MBoard.  You need to move this jumper to the other position to get rid of the splash and allow access to the BIOS.  Mainly on packaged PCs whos manufacturers do not want customers changing BIOS settings.  With the jumper in the lock position none of the normal keyboard sequences will bring up the BIOS.
BobA
mahuti
« Reply #9 on: November 07, 2005, 02:08:23 am »
You could choose the easy route, and just put in a seperate switch for the monitor... turn it on yourself a few minutes after powering up the rest of your cab. I did  this and I love it... mainly because the computer can run constantly, while I can just turn on and off the monitor / audio, etc.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #10 on: November 07, 2005, 02:46:09 am »
JCrouse used a solid state timer.  It can delay start up by up to a minute, but there are many to choose from.  I believe he said his ran around $45.  Here is a link to a catalog that has them:
http://www.mouser.com/catalog/623/1247.pdf
As far as getting rid of the splash screen, check out the BYOAC book.  I just read over that section.
Havok
  • Trade Count: (+17)
« Reply #11 on: November 07, 2005, 09:21:46 am »
One thing you can do is remove all the status screens and set it to "quick boot" - these are all different per bios, however most have the option to do so. Most likely you will never completely get rid of the bios screen.
Just leave the machine running all the time!
lordtodd75
  • Last login:July 21, 2020, 01:42:37 am
  • I especially hate punks!
« Reply #12 on: November 14, 2005, 09:32:24 am »
Install an old pci slot graphics card. Make sure you dont plug your monitor into it though. Setup in your bios to boot from the pci. When your machine boots it will send its video signal to the pci, which has nothing plugged into it, thusly(is that a word) giving you a black screen. when your OS boots it should load the drivers for your AGP or onboard graphics card. presto.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #13 on: November 14, 2005, 12:49:40 pm »
Is it that bad to have PC boot info? Are you trying to defraud someone and need them to not know it's PC based???
NO MORE!!
Lilwolf
« Reply #14 on: November 14, 2005, 03:37:49 pm »
There is a power strip that will only turn on other items after the USB makes a connection.    It was pretty cheap if I remember right.
Anyway, search around for smart power strips.  There are two types and you want the other one...
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #15 on: November 14, 2005, 04:15:01 pm »
I just use the mobo's power button to bring the system in and out of standby instead. Less time to the front end, and no bios.
« Last Edit: November 14, 2005, 08:32:21 pm by SpamMe »
JLR2000
  • Last login:December 28, 2025, 10:50:05 pm
  • There is NO Sanctuary...
    • WWW
« Reply #16 on: November 14, 2005, 08:31:03 pm »
Yeah, I just leave the PC powered on....
The switch on the back controls the TV and the powered speakers....so when it's "off" it's really just monitor and sound off....
I guess some people don't like to leave their PCs on, but let's see....I have 10 running all the time.... ;D
and no, my electric bill doesn't change if I turn them all off....
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #17 on: November 14, 2005, 09:21:46 pm »
Wave your arms around and fake a stroke until the BIOS screen passes. i.e., distract your visitors during boot. It's a cheap hack I guess.  :D
-pmc
rotinapple
  • Last login:November 15, 2005, 12:51:56 pm
« Reply #18 on: November 15, 2005, 09:54:24 am »
I would recommend to turn off your PC and just live with the bios screen.  It's a small sacrifice, you don't want to unnecessarily run your PS if your not at home.
Lilwolf
« Reply #19 on: November 15, 2005, 10:31:11 am »
The Mini Power Minder
http://www.thinkgeek.com/gadgets/electronic/6ee4/
So you turn on your computer... Then the power minder will not turn on until after your USB connects.  I believe this is when your LED comes on your mouse but I don't know for sure.
Anyway, cool item... I've been meaning to buy one for ages.
big daddy
  • Last login:May 01, 2019, 12:16:13 pm
« Reply #20 on: November 15, 2005, 02:11:41 pm »
concur with this.  I haven't done it yet, but seems the easiest option that people have recommended.  You can get an old graphics card super cheap if you don't have one lying around in an old pc anyways.
No special programs needed and cheap.
IG-88
« Reply #21 on: November 15, 2005, 09:47:17 pm »
Nice, RayB...... ::)
-HarumaN
RandyT
    • GroovyGameGear.com
« Reply #22 on: November 16, 2005, 10:01:40 am »
I touched on this very briefly in the "Blinky lights" thread.
You could use the GGG LED-Wiz (now in public Beta) to control the power to the monitor or to switch the 3 video signals.
You would just need a 5v relay, or in the case of the 3 video signals, a cheap analog switch chip.
You would then only need to send the right command to the LED-Wiz to turn those outputs on just before your front end loads.
And think of all the cool stuff you could do with the other ~30 outputs ;)
RandyT
