Author Topic: Any way of disabling insert coin on an IPAC?  (Read 1759 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: October 21, 2005, 04:48:33 am »
i want to use a coin mech rather than have the (tempting) option of pressing shift and one of the other keys to get a credit.
is it possible to disable the shift key combo that gives credits on an ipac?
Franco
Re: Any way of disabling insert coin on an IPAC?
« Reply #1 on: October 21, 2005, 07:11:41 am »
You must remain strong my child. Find inner strength and restrain yourself.
Seriousl tho, open the WinIPAC utility, go to Table View, right click whatever is currently the insert coin shift button [usually P1 Start + P1SW1 (5)] and then select None from the list.
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
« Reply #2 on: October 21, 2005, 08:48:30 am »
You could also just change the button required to insert a coin in MAME to whatever input you've hooked the coin mech up to.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
Franco
« Reply #3 on: October 21, 2005, 09:43:01 am »
Good point!   :P
tray262
  • Last login:February 13, 2022, 07:07:52 pm
« Reply #4 on: October 21, 2005, 11:04:37 am »
I'd say that's your best option.
Lilwolf
« Reply #5 on: October 21, 2005, 03:57:19 pm »
I don't know... I would say you should do both.
disabling any non-used keys are good... ESPECIALLY the start1 and start2 combo to ESC... I have NO idea why anyone would want that.  It messed up about 10 games before I finally put a keyboard on my cab and turned it off...
StephenH
« Reply #6 on: October 22, 2005, 04:35:32 pm »
Set it to 5, and wire the coin input to output a 5 key
