Author Topic: Fonts - Which ones are you using for your Front End?  (Read 2205 times)
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
« on: October 12, 2005, 10:00:07 pm »
I just want to check out some different fonts to use.
So what are you using?
mahuti
Re: Fonts - Which ones are you using for your Front End?
« Reply #1 on: October 13, 2005, 02:45:08 am »
Arial.
Pretty sad, really... seeing as how I'm a designger... user interface one at that. Cobblers shoes.. you know how that goes.
I may eventually try out FFF business, 04bit, and xpdr01..... pixel fonts.
« Reply #2 on: October 13, 2005, 05:02:38 am »
'Small Fonts' as my resolution is so low (368x240)...
D5A1AC
« Reply #3 on: October 13, 2005, 07:05:53 am »
I used the default one in Jcrouse's mamewah layouts but then I switched to Tahoma with a different layout. I think it looks pretty nice.
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #4 on: October 13, 2005, 07:07:19 am »
Arial in advmenu at 768x576 (using a special build that removes interlace flicker)
  • Last login:Yesterday at 11:03:36 pm
« Reply #5 on: October 13, 2005, 10:18:07 pm »
If a skin is built correctly, the author should include the proper font and it should match in theme with with rest of the skin.  So unless you are running game launcher what font you are useing typically is whatever font it came with.
buks
  • Last login:January 28, 2011, 06:43:25 pm
  • Squash the Sno-Bees !
    • Arcade Machine Construction
« Reply #6 on: October 14, 2005, 08:08:31 am »
"Slicker" font - very nice and clean. Its free too - http://www.abstractfonts.com/fonts/static_Letters/S_5.html
I messed about with loads of fonts but none of them looked right. Eventually I stumbled on a post here somewehere that mentioned Slicker.
Hope that helps.
Buks
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: October 14, 2005, 11:21:13 am »
Incidentally, "Slicker" is the font that comes with GameLauncher.
NO MORE!!
