Author Topic: FS: Thermaltake Fanless103 CPU Cooler  (Read 1776 times)
Ninja Supremacist
  • Last login:February 21, 2008, 03:17:05 pm
  • I, alone, am the Master.
« Last Edit: October 04, 2005, 09:16:36 am by Ninja Supremacist »
Here's to those who say they do...
Here's to those who say they don't...
Here's to those who say they will
And later decide they won't.
Ninja Supremacist
Re: FS: Thermaltake Fanless103 CPU Cooler
« Reply #1 on: October 04, 2005, 09:17:18 am »
Ok... now $20 shipped.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #2 on: October 04, 2005, 11:26:40 am »
is this new or used? if used how well does it work?
Slow In Fast Out
Ninja Supremacist
« Reply #3 on: October 05, 2005, 06:07:14 pm »
Used.
Works very well.  The performance is on par with my Venus cooler and completely silent.
Keep in mind that case ventilation is extremely important with a heat pipe setup.  Also, some motherboards rely on the CPU fan to cool the Northbridge.  There are mounting points on this unit for an additional fan if necessary or desired.
This thing is huge.  It fits perfectly in my Lian-Li PC61 as it should in any ATX case.  Keep ventilation in mind though.  Can't say it enough.  I bought an Ultra xconnect power supply to open up airspace.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: October 05, 2005, 06:18:49 pm »
Yes, the reviews for this heatsink say you need good airflow.  Especially if your northbridge needs the cpu fan airlfow which it won't get after this.
I've seen the reviews, impressive for  a fanless.  Which makes me wonder if you add a fan it should work very good.  Could even get a low rpm fan to keep the noise down.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #5 on: October 05, 2005, 08:04:37 pm »
Ninja Supremacist
« Reply #6 on: October 05, 2005, 08:50:24 pm »
Are you really going to put the $12 model on your athlon64?
Your CPU won't fry as cooling sites/stores try to scare people but it will not be stable.  You'll crash in Arkanoid repeatedly.
SOAPboy
  • ..::GeeK::..
« Reply #7 on: October 05, 2005, 08:55:49 pm »
Ninja Supremacist
« Reply #8 on: October 05, 2005, 09:07:22 pm »
Maybe you need one of those human coolers.  Seriously, lighten up.  I know you used the theoretical "CAN" and I continued what I suspected would be discussion.  I didn't accuse you of thread jacking or killing my sale, I simply replied to your post.
Peace.
SOAPboy
  • ..::GeeK::..
« Reply #9 on: October 05, 2005, 09:10:16 pm »
Ninja Supremacist
« Reply #10 on: October 05, 2005, 09:14:53 pm »
Ok.  Ok.  Ok.
