Author Topic: HVLP Painting, equipment needed?  (Read 1112 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« on: September 28, 2005, 11:05:36 am »
I've been looking around at hvlp sprayers, what is the most inexpensive way to get into a setup?
I need a sprayer and compressor. The problem I see is that most of the need LOTS of air to function.
example..
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=7902
# 40 PSI max.
# Average air consumption: 10 CFM
And most of the compressors are.
120V, 4HP (peak), 3HP (rated,) 3400 RPM, Air delivery: 4.5 SCFM @ 115 PSI; 5.6 SCFM @ 90PSI; 6.25 SCFM @ 70 PSI; 7.2 SCFM @ 40 PSI; Auto shutoff @ 115 PSI; Restart @ 85 PSI
So the max that this compressor seems to output is only 7.2 cfm.
Am I reading this wrong?
Help..
Thanks.
Later,
dabone
rdagger
Re: HVLP Painting, equipment needed?
« Reply #1 on: September 28, 2005, 02:00:58 pm »
I have a Campbell Hausfeld 2050 HVLP sprayer.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #2 on: September 28, 2005, 05:18:44 pm »
I have read favorable reports on this one:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91772
It is cheap enough, and no compressor is needed. I do not have any personal experience though, so YMMV.
ikyoto
  • Last login:December 28, 2005, 10:30:07 am
  • almost done!
« Reply #3 on: September 28, 2005, 05:32:25 pm »
You could also try a local body shop supply store (maybe even an auto parts store depending). They should have reasonably priced guns and should be able to direct you to the right compressor solution.
I work for a auto parts distributor in ohio, and I know our refinishing centers sell lower cost guns and sell compressors, quality though I'm unsure of. I've only used SATA and Devilbiss guns
crashwg
« Reply #4 on: September 28, 2005, 05:38:55 pm »
If you go the route of compressed air you may want to look into a "condensate seperator".  Otherwise you may have condensation (water) comming out with the paint which would not be so good for the finish.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
