Author Topic: FS: Lots of Coin Mechs  (Read 6591 times)
AlexC
  • Last login:May 06, 2012, 05:18:05 pm
  • "Beware, I live!"
Re: FS: Lots of Coin Mechs
« Reply #40 on: May 07, 2006, 03:25:04 pm »
Bummer  :'(
jtkauff
  • Last login:July 07, 2006, 05:05:03 am
« Reply #41 on: May 08, 2006, 01:31:57 pm »
Any quarter mechs left? I'm assuming not, but figure it's worth asking.
cscon115
  • Last login:June 12, 2009, 02:45:29 pm
  • Sock it to me!
« Reply #42 on: May 08, 2006, 06:45:36 pm »
I don't have one in front of me, but I *think* there are two holes per side, top and bottom.  I can say for certain in the AM.
The nibs are definitely part of the mech (molded plastic) but that's really not a big deal. If you need nibs, and there aren't any, you don't have to drill and tap, you can just take a metal nib and screw it into the mech.  I do it at work all the time.
I am a tad confused. Maybe I am just silly... but you say that there are two holes per side top and bottom. This would mean that the nibs are not a molded part of the side. Then the next sentence you say the nibs are definitely part of the mech. These both can't be true at the same time.
I am looking for the mechs with threaded holes on the side. I do not want coin mechs with molded nibs. I have a bucket Happ plastic coin mechs that have the nubs molded into them and I do not want any more of these ever again.
Do your mechs have threaded holes on the side?
Do your mechs have molded nubs instead of threaded holes?
Is there a maker's name on them (Happ,Imonex,CoinMechanism) this might answer the above questions.
Dan
Ronald Reagan is too liberal for me.
SirPeale
  • Green Mountain Man
« Reply #43 on: May 09, 2006, 01:09:41 am »
IIRC They're Coin Controls mechs.  The nibs are molded into the sides.  They're hollowish, so if you remove them, there is a hole remaining.  So yes, my statement is true.  Both having holes on the sides AND having molded nibs.  If the nib is missing you can take a metal nib and screw it right into the hole that remains.
So...overall, since there are molded nibs on these, *you* don't want them.
cscon115
  • Sock it to me!
« Reply #44 on: May 09, 2006, 07:39:12 pm »
Hollow? Wow, now that is a useful bit of info.
The ones from Happ are solid and made of that rather brittle black plastic that looks like it might even be a fiberglass composite. That is my frame of reference. I had no idea that there were hollow nubbed mechs in existence.
I tried working the Happ ones (they stink). They were hard and after you snapped them off you end up with a very rough surface that was a bear to drill straight. I really hate the Happ ones that I got last round. Furthermore the batch that I received jammed and false reject at a very high rate. I now have 18 mechs that are useless to me that I paid a lot for, I have to alter to fit into my doors, and after all of the work I am unhappy with the results.
Knowing nothing about the coin mechs in your possession, I can only ask questions and try to figure out what you have.  I was mistaken when I assumed that the nubs were solid. I am sorry for any offence that you may have taken.
SirPeale
« Reply #45 on: May 09, 2006, 07:54:39 pm »
I am highly offended.  You are now my enemy.
I will now suggest to the BYOAC crowd that we form two factions: those who follow me, and those who follow you.
Those who follow me will have splendor, ten credits per coin, plenty of arcade goodness, and a million allowances worth of quarters.
Those who follow you will receive game over and DEATH DEATH DEATH.
Seriously though...
I'll dig up a mech later and take a picture of the sides to show you what I mean.
The Happ ones aren't really meant to be modified more than once.  If you don't need the nibs you take them off, then leave them in the machine.  Or move them to a machine that has the same constraints.
cscon115
  • Sock it to me!
« Reply #46 on: May 10, 2006, 10:33:50 am »
Ha Ha! I will now join your ranks as a double agent and report back to myself! (Do you think anyone would notice?)
I await your pics with abated breath (no I don't eat worms).
Dan
Capthowdy
  • Last login:April 13, 2015, 03:33:18 pm
« Reply #47 on: May 21, 2006, 03:40:09 pm »
anyone know if any of these coin mechs will fit this door?  it looks pretty old.  should I just replace the door?
SirPeale
« Reply #48 on: May 21, 2006, 05:09:34 pm »
Just a standard door, any standard mechs will fit.  Will need four nubs on the corners.
Capthowdy
« Reply #49 on: May 21, 2006, 06:01:14 pm »
so how do I get one of your amazing mechs and these magical "nubs" you speak of?   :)
what ARE nubs?
also...do you have any quarter mechs left or do they all take quarters?
SirPeale
« Reply #50 on: May 22, 2006, 06:52:01 am »
I'd have to look, but I may have at least two quarter mechs left.  Most everything else is .900".
The nubs are the little things in the corners of the mechs that hold them in the coin door.  The Midway door you have requires all four to be intact.  They could either be the original ones, or the little metal ones that screw into the sides.
SirPeale
« Reply #51 on: May 24, 2006, 06:26:17 am »
Hey, I just dug up some quarter mechs.  Yay!
SirPeale
« Reply #52 on: June 12, 2006, 07:31:22 pm »
I just found a bunch of quarter mechs!  Supplies are limited, act now!
SirPeale
« Reply #53 on: June 16, 2006, 08:50:45 am »
Still have some quarter mechs left.
