Author Topic: N64 to joystick port? or USB?  (Read 1614 times)
Kyosho
  • Newbie
  • Last login:December 01, 2024, 04:19:14 pm
  • Wish I were a fish
« on: January 12, 2003, 06:05:31 am »
I'm completely new to all of this stuff. This is probably not possible, but is there a way to make an N64 controller work in a joystick port or USB? Something I can build myself, that is. I've seen things for the parallel port, but nothing for this, so I assume it's not going to work.
I know I could buy an adapter (probably USB right?), but I'd rather not...
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
Re:N64 to joystick port? or USB?
« Reply #1 on: January 12, 2003, 09:00:06 am »
The N64 is one  of the most difficult controllers to interface.
Afaik nobody has interfaced it to the J-stick port .
Your best options are.
* buy a usb adapter
* build the parralel port adapter (difficult)
* forget N64 and build the PSX parallel adapter (easy)
I went with the last option  and built a pair of  psx controller
adapters. These were very easy to build,I can plug and unplug them from the front of my cab, and it only took about 2 hours to build both of them.They were also very
cheap ,I think they cost about $7 each and that includes a $4 extention cable. I use them with the nes/snes emulators
and they work great. I don't run any N64 emus but I'm sure they would be fine.
                                    Good luck
                                     Slug54
toilet
  • Last login:November 11, 2005, 11:53:45 am
    • Briefcase Emulator
« Reply #2 on: January 12, 2003, 09:13:12 am »
I have a couple of the N64 -> USB adapters and they work great. http://www.levelsix.com/products/playstation/pcusbadapter.shtml. They're pretty cheap and fairly unintrusive for what it's worth.
DF
  • Last login:July 27, 2006, 05:48:55 pm
« Reply #3 on: January 13, 2003, 01:37:45 pm »
I own 2 Adaptoids.
http://jandaman.cybrhost.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=n64adaptoid&Category_Code=N64
It works great but isn't cheap.
I have never heard any good things about the PSX/N64 adapters but I haven't tried them myself.
I would buy one rather than build one as the paralell (sp?) port isn't all that fast and you would only be limited to 1 controller.
