Author Topic: 6-Button Layout and default mame buttons...  (Read 4086 times)
rbarr110
  • Last login:July 25, 2025, 02:24:58 pm
  • I already built my own arcade controls!
« on: August 27, 2005, 01:41:42 am »
OK - I am wiring up my CP with an I-Pac and trying to figure out what button should be 1SW1, 1SW2, 1SW3, etc etc up to 6.
I have a 6 button layout - 2 rows, 3 columns very typical from what I have seen on most mame cabs.
Should the top row of buttons from left to right be SW1, SW2, and SW3?  Or SW1, SW3, SW5?
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
Re: 6-Button Layout and default mame buttons...
« Reply #1 on: August 27, 2005, 01:49:26 am »
I have a similar question. Due to size restrictions, I must use two colunms of 3 buttons on my CP. Which of the following should I use?
1 2
3 4
5 6
or
1 4
2 5
3 6
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
Bursar
  • Last login:September 14, 2005, 06:57:07 am
« Reply #2 on: August 27, 2005, 03:43:16 am »
I did mine as 123 across the top and 456 underneath.
Don't forget that you can remap controls in the game if things aren't as comfortable as you want.
For 2 colums, I would go for the first option. It put buttons 1 and 2 next to each other, and button 3 should be comfortable enough for the thumb.
I would then remap controls in Street Fighter games so that the left column was punch and the right coumn was kick.
If in doubt, buy some cheap chipboard and make a temporary CP in the desired layout and test it for a while.
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: August 27, 2005, 01:00:01 pm »
This has been asked a lot.
For classics, I prefer
4 5 6
1 2 3
For Street Fighter:
1 2 3
4 5 6
Of course, you can re-map either one to use these buttons in MAME, so it's really just which one you play more of.
