Author Topic: Cutting T-Molding to Length  (Read 2360 times)
« on: August 22, 2005, 09:41:59 pm »
OK, this is going to sound silly but how do you make a 90 degree cut when cutting t-molding to fit around the edges of your cab?
« Last Edit: August 23, 2005, 08:01:45 am by javeryh »
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
Re: Installing T-Molding
« Reply #1 on: August 22, 2005, 09:53:35 pm »
When you say 90deg do you mean perpendicular to the axis of the molding?
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
« Reply #2 on: August 22, 2005, 10:43:35 pm »
yeah, it's the first way - just simply cutting the piece to length.  I am laying it flat but I can't seem to make the cut perfectly square and I want to do it right...
Kremmen
  • Last login:January 17, 2008, 04:46:49 am
  • Look, on the scanner, it's Uranis!
« Reply #3 on: August 23, 2005, 01:47:08 am »
I used a chisel.  Lay the t-molding flat on some wood, line the chisel up straight and tap it with a hammer.
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #4 on: August 23, 2005, 04:56:19 am »
Hi,
Do a cut to the t-molding like this:
« Reply #5 on: August 23, 2005, 08:01:21 am »
Thanks for all the suggestions - anyone else have a method that requires less eyeballing and is more idiot-proof?
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Cutting T-Molding to Length
« Reply #6 on: August 23, 2005, 08:15:40 am »
Do you have a t-square? or anything that' make a 90 deg angle?
If so, lay it flat on its back, trim off the barbed edge with a razor knife.  align an inside edge of the T-Square with the edge of the molding, move the t-square so the perpendicular piece is exactly where you want it, and run the razor knife along the perpendicular edge of the t-square.
No eyeballing, perfectly straight cut.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #7 on: August 23, 2005, 12:47:42 pm »
use scissors?
I want my own arcade controls!
whammoed
  • Last login:Today at 10:38:15 am
  • Crack don't smoke itself
    • NiceMite
« Reply #8 on: August 23, 2005, 12:51:38 pm »
I use a pvc pipe cutter.  Not something I bought for t-molding, already had it.  Works great.
