Author Topic: I-Pac problem#2 Solved!!!  (Read 3967 times)
Q*Bert_OP
  • Oh yes, we did!
« on: August 04, 2005, 09:35:09 pm »
My I-pac is giving all games 2 credits for every coin instead of 1. All games are set to 1 coin 1 play, please help me.
« Last Edit: August 05, 2005, 12:39:21 pm by qbert247 »
AlanS17
    • AlanS17
Re: I-Pac problem#2
« Reply #1 on: August 04, 2005, 09:50:06 pm »
Sounds like you're shorting the coin 2 switch somehow every time you short coin 1. So you're simultaneously dropping coins in both slots and doubling up the credits.
Q*Bert_OP
  • Oh yes, we did!
Re: I-Pac problem#2
« Reply #2 on: August 04, 2005, 09:52:49 pm »
Only coin 1 is wired
AlanS17
    • AlanS17
Re: I-Pac problem#2
« Reply #3 on: August 04, 2005, 09:53:36 pm »
Then check your MAME config. Make sure coin 1 isn't triggering both coin switches in MAME.
AlanS17
    • AlanS17
Re: I-Pac problem#2
« Reply #4 on: August 04, 2005, 09:54:15 pm »
Coin 1 should be the 5 key and coin 2 should be the 6 key. Make sure you don't have the 5 key mapped to both coins.
AlanS17
    • AlanS17
Re: I-Pac problem#2
« Reply #5 on: August 04, 2005, 09:55:41 pm »
Open up notepad.exe in Windows if you can. Then drop a coin. What's the output? (You can substitute notepad for a DOS prompt or anywhere to see the text display.)
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
Re: I-Pac problem#2
« Reply #6 on: August 05, 2005, 02:18:31 am »
mine does this too.... when i press 1player start it works fine just 1 coin, but 2plyaer start drops 2 coins?
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
JCL
  • Last login:April 20, 2008, 04:11:10 pm
  • What Are You Looking At?
Re: I-Pac problem#2
« Reply #7 on: August 05, 2005, 02:20:31 am »
Do you have this wired to a real coin mechanism or a switch? A switch probably works correctly, but an old badly adjusted coin mech might be problimatical.
I tend to doubt it is the ipac. I think software or other harware is more likely at fault.
cdbrown
  • Bowowow
Re: I-Pac problem#2
« Reply #8 on: August 05, 2005, 02:55:02 am »
I had a problem with a few microswitches that would register 2 clicks every time I pressed the button.  Issue was internal to the switch.  I slowly pressed in the small actuator on the switch and as it was being depressed it registered one click (closing the circuit), then as I released it registered a second time (closing the circuit).  In notepad, instead of it continually repeating the keystroke as it was held down, it only registered once - once button fully depressed the circuit in the switch would become open.
Tiger-Heli
    • Tiger-Heli
Re: I-Pac problem#2
« Reply #9 on: August 05, 2005, 07:43:45 am »
Do you both (Qbert247 and joshbr7257) have coin buttons wired to discrete I-PAC terminal, or are you using the shift function to add coins?
AlanS17
    • AlanS17
Re: I-Pac problem#2
« Reply #10 on: August 05, 2005, 09:09:10 am »
You mean those aren't "1 credit" and "2 credits" buttons? j/k
Q*Bert_OP
  • Oh yes, we did!
Re: I-Pac problem#2
« Reply #11 on: August 05, 2005, 11:59:28 am »
it's hooked up to a coin switch.
i put a newer computer, and a newer version of mame in the cabinet, and all of a sudden , it does this.
Q*Bert_OP
  • Oh yes, we did!
Re: I-Pac problem#2
« Reply #12 on: August 05, 2005, 12:37:57 pm »
Problem solved!
The coin switch was only wired ti coin 1, but i had configured player 2 coin to (5) as well :-[
AlanS17
    • AlanS17
Re: I-Pac problem#2 Solved!!!
« Reply #13 on: August 05, 2005, 12:41:45 pm »
Whoops! Yup, that'll do it.
