Author Topic: +5v from DB9 serial port?  (Read 2358 times)
Effayy
  • Last login:August 18, 2006, 02:09:07 pm
  • Slowest....Cab Builder.... EVER.
« on: August 02, 2005, 10:44:36 am »
Tried searching through Google, but to be honest, if the answer was staring me in the face, I wouldn't realize it.  :-\
I have the connectors and cabling needed to attach my new 4x40 LCD to my DB9 serial port, but can you draw +5v from it, or would I need to get my power from elsewhere?
I'm assuming that old DB9 prephirals (mice etc) had to draw power to send a signal, right?
- FA
RandyT
  • Last login:Yesterday at 05:14:12 pm
    • GroovyGameGear.com
Re: +5v from DB9 serial port?
« Reply #1 on: August 02, 2005, 10:54:52 am »
If I'm not mistaken, they siphon power from the CD and/or other lines.  The signals are +12v and -12v, but at very low current levels.
I don't think I would try to power a device like you are describing from them.  Remember, a mouse is only a small, low-power chip and a couple of opto-components, so it doesn't need much power.
RandyT
ultramagnus
  • Last login:September 09, 2005, 02:10:45 am
« Reply #2 on: August 02, 2005, 10:56:26 am »
erg, try to draw enough currernt to power a lcd from your serial port and you blow the port
either take it from the molex connectors in your pc (yellow, 12v, red, 5v) or from the power lines in a USB cable (5v)
