Author Topic: Change default player one position in cocktail mode?  (Read 1694 times)
gonzobrian
  • Last login:April 18, 2011, 08:42:08 pm
  • This space for rent!
« on: July 20, 2005, 08:21:00 pm »
Is it possible to change the default player one positon from the right side of the cabinet to the left?
I am finishing up a 3 control panel cocktail cab and facing the front of the cabinet player one defaults to the right CP.  Was this normal in the original cocktail cabs?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Change default player one position in cocktail mode?
« Reply #1 on: July 20, 2005, 09:57:49 pm »
Well, original cocktails didn't have controls on three sides. Maybe you put the side controls on the wrong side?
NO MORE!!
gonzobrian
« Reply #2 on: July 20, 2005, 11:17:25 pm »
I think that was a joke but again it has been a long day and will be a long night.  From my memory of being a kid in the 80's I knew I never saw a 3 CP cocktail.  I just described my cab so that I was clear in what I was asking about the side CP's.
Actually I remember the last time I played a cocktail cab.  I was in the Boy Scouts on my way to Philmont Scout Ranch in New Mexico.  We stoped at a Pizza Hut and we all had a go at Pacman.  ;D
Boy those were the days.
gonzobrian
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #3 on: July 20, 2005, 11:22:53 pm »
For the affected vertical games, simply flip the screen in MAME (technique depends on version used and there are those better versed than I in the details).
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
gonzobrian
« Reply #4 on: July 21, 2005, 12:02:01 am »
Cheers.
Cool thanks CheffoJeffo.  I'm using Mame .85.  I don't know if I was clear.  I can run vertical games vertically, and horizontal games horizontally, but I want to flip cocktail games so that player one is sitting on the left side of the cabinet.
Are you saying that there is a way to change this in Mame without altering the orientation of my 3 CP?
Thanks,
gonzobrian
CheffoJeffo
« Reply #5 on: July 21, 2005, 07:14:29 am »
On my 3-sider, I use MAME32, so handle all of the configs through the menus, then run the games using MAMEWah.
For MAME, I thinkyou are looking for the -flipx / -flipy options, but I'm not the best MAME guy ... someone will undoubtedly chime in shortly with a more complete/correct answer.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
gonzobrian
« Reply #6 on: July 21, 2005, 12:04:45 pm »
Cheers.
Thanks again.  Thats a starting point for me to look into.  Any one else know anything about this?
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
« Reply #7 on: July 21, 2005, 02:04:43 pm »
If I understand you correctly, you can do what you want just by using the -rol or -ror tags for command prompt mame when you're running a vertical game.  I have a vertical cocktail setup, and the 'player 1' and 'player 2' sides have slightly different controls.  (one side has a spinner/joystick and the other side has a trackball/joystick).  In addition to this, I have a small 2 player tabletop joystick setup that I can place on the cocktail, which is essentially the 3rd (horizontal position) control panel.  Basically, my machine looks like this:
                   screen
trackball        screen         spinner
                   screen
                 2 joysticks
If I want to play a streetfighter type game, I just run mame as is.  The screen is oriented horizontally, and everything is fine.
If I want to play a vertical spinner game like tempest, where player 1 is the spinner side, I run mame with a -rol tag, which rotates the screen orientation to the the left.
If I want to play a vertical trackball game like centipede, where player 1 is on the trackball side, I run mame with a -ror tag, which rotates the screen orientation to the right.
Does this clear things up?
Good luck,
88mph
« Last Edit: July 21, 2005, 02:06:59 pm by 88mph »
gonzobrian
« Reply #8 on: July 21, 2005, 02:32:50 pm »
Yes thanks 88mph  :D
If I understand you I can set up each game with -rol and all the cocktail games will have player 1 on the left side.
So this setting is in mame.ini?  Or do I have to set up some kind of dat or ini file for each game?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #9 on: July 21, 2005, 02:41:11 pm »
autoror or autorol options in mame.
gonzobrian
« Reply #10 on: July 21, 2005, 03:47:38 pm »
Hey cool.  I'll give that a go.  8)
