Author Topic: Need specs on a real jukebox  (Read 4551 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: July 15, 2005, 10:19:21 pm »
I might be getting an older AMI Jukebox, Model R-92. Its being let go really cheap, but it displays an error code. Its capable of playing 45's and CDs. Does anyone know where I can find what the error codes mean? And what the ratings of the amp and speakers are?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
Ken Layton
  • Guru
  • Technician
Re: Need specs on a real jukebox
« Reply #1 on: July 16, 2005, 12:18:42 pm »
The error codes are listed in the service manual. I have a list of some of the errror codes. You can buy brand new jukebox manuals (and parts) from www.victoryglass.com
The Victory Glass part numbers for the manual you need is:
70-5769 (R-559) Rowe-Ami model R-92 Field Service and Parts Manual, 184 pages! ($39.95). Worth every penny!
If you'd like (or need) to pay less money check out ebay seller jeffwager and his manual selection.
This jukebox uses Rowe # 6-09931-02 (a.k.a. 60993102) 130 watt amplifier (65 watts per channel). If your box is missing the amplifier, I have an extra rebuilt tested ready-to-go amplifier for your machine. Shoot me an email at KLayton888@aol.com
BTW, the R-92 is great sounding and dependable running machine. The jukebox is old enough now that the battery for the memory in the Central Control Computer (CCC) is probably dead/weak and needs to be replaced. It's a lithium 'coin' style cell and it's soldered in.
« Last Edit: July 16, 2005, 12:28:52 pm by Ken Layton »
USSEnterprise
    • USS Odyssey
« Reply #2 on: July 16, 2005, 04:14:31 pm »
Thanks a lot. The one I'm looking at also comes fully loaded with 45s and CDs, and comes with the manual. I think I'm gonna get it.
USSEnterprise
    • USS Odyssey
« Reply #3 on: July 16, 2005, 05:17:40 pm »
Right now, its apparently getting something called "ERRO4" on the LED segment display. My guess at worst case scenario is a bad chip of two.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: July 16, 2005, 07:02:41 pm »
You're gonna steal that jukebox. Error 4 is "battery voltage too low" on the Central Control Computer board. The battery is shot and needs to be replaced. It uses a single soldered in "CR2032" type lithium coin cell (3 volts).
I replace it with a slip in battery holder and a common grocery store lithium coin cell CR2032 slip in. If you go that route then get Mouser # 534-1061 ($1.44) battery holder which will solder in place of the original battery.
Mouser (www.mouser.com) has the original soldered in batteries as well (choose any one of these):
614-CR2032FH Renata brand ($1.43)
658-BR2032-1HE Panasonic brand ($1.96)
672-60324 Varta brand ($1.10)
If you have a Batteries Plus store in your area they should stock those batteries.
Radio Shack special order # 960-0216 lithium battery.
USSEnterprise
    • USS Odyssey
« Reply #5 on: July 16, 2005, 09:23:43 pm »
Thank you very much! I got one of those with the holder I can rip off an old mobo. Awesome!
Chris
    • Chris's MAME Cabinet
« Reply #6 on: July 16, 2005, 09:48:18 pm »
You ar now required by law to post pics when you get it.  :)
--Chris
USSEnterprise
    • USS Odyssey
« Reply #7 on: July 16, 2005, 11:04:45 pm »
Definitely will ;D. Its in bad cosmetic condition, and needs light bulbs apparently. They say they don't know what it needs to fix the problem with the error. hehehe.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: July 17, 2005, 12:33:33 am »
The light bulbs that light up the grill on that model I think are # S-11 Sign bulbs (11 watts). Don't use any other wattage bulbs or you'll damage the light flasher/controller unit or melt the plastics. You can choose whatever color (they are transparent colored bulbs) bulb you want in this type of light bulb, but the common colors are yellow, red, orange, blue, and green. The yellow bulbs look great on this kind of jukebox.
I've seen some of these bulbs at Home Depot and some lighting stores.
USSEnterprise
    • USS Odyssey
« Reply #9 on: July 17, 2005, 12:37:13 am »
Theres a big electrical and lighting place where I buy the #44s for my pinball machine. And can you still get the stylus for the turntable?
USSEnterprise
    • USS Odyssey
« Reply #10 on: July 17, 2005, 12:39:22 am »
This is my first Jukebox, so I'm sorry to be asking so many questions :)
Ken Layton
  • Guru
  • Technician
« Reply #11 on: July 17, 2005, 01:05:56 am »
Yes, you can buy the needle at www.victoryglass.com
You can also buy records from them as well as title strips.
Check out the titlestrip software for printing your own title strips at www.lowprofilesoftware.com
USSEnterprise
    • USS Odyssey
« Reply #12 on: July 17, 2005, 01:26:46 am »
Forget about it. Guy sold it off. Got a better offer ($200) and took it. Damn!
Clonedsheep
  • Last login:March 29, 2025, 09:59:42 pm
« Reply #13 on: August 02, 2005, 01:30:47 pm »
Damn, I was getting excited for you.  that sucks.  >:(
The king of 1/2 done projects
