Author Topic: fl0yds Rotary Adapter plug question  (Read 951 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: July 13, 2005, 02:16:44 pm »
http://www.markoates.com/rotary/TechSupport.htm
I am a bit confused.  I finished my soldering on the switch, now I need to connect my wires to the plug.  When I look on Mark Oates' website instructions i see the first table with the following info
Table 1
13-pin Connector Rotary Switch
Pin 1                    Pin 1
Pin 2                    Pin 2
Pin 3                    Pin 3
and so on until ....
Pin 12          Pin 12
Pin 13          Pin A
Then a little farther down I see this table
13-pin Connector    Rotary Switch    Druin's PCB
Pin 1      Pin A        Pin 1
Pin 2      Pin 1       Pin 2
Pin 13      Pin 12       Pin 13
So does the cable from pin "A"  on the switch go to pin (1) on the connector or (13) ???
Also is there a "top" or "bottom" on these connectors (they're not in front of me now).  Does it matter what side the pin one goes into?
Thank you
fl0yd
  • Last login:April 15, 2009, 12:24:39 am
    • Rotary Adapter for Midway 49-Way Joystick
Re: fl0yds Rotary Adapter plug question
« Reply #1 on: July 13, 2005, 05:01:30 pm »
That's a good catch.  I'd updated the one table, but failed to update the other.
Pin A on the switch goes to pin 13 on the connector, and pin 13 on druin's.
(I'll double check this when I get home.)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: July 13, 2005, 05:24:34 pm »
A*W*E*S*O*M*E*
fl0yd
« Reply #3 on: July 14, 2005, 06:20:29 pm »
Pin A on the switch needs to connect to Pin 13 on Druin's and on the 13 pin connector.
I've updated the site.
Thank you for pointing that out.  :)
Mark
