Author Topic: Hey Experts! Do I need an Opti-Pac?  (Read 1304 times)
Ldsfunaz
  • Last login:March 07, 2006, 06:32:01 pm
  • "Super NinCadeO, Sega Genesis!!"
« on: July 10, 2005, 11:39:07 pm »
I'm gonna Go with a USB Happs and a tornado spinner.
krick
  • Gotta have blue hair.
Re: Hey Experts! Do I need an Opti-Pac?
« Reply #1 on: July 11, 2005, 12:54:31 am »
If you have a USB trackball and USB spinner, then an Opti-Pac is totally useless for you.
An Opti-Pac is designed to have devices direct wired into it.
If you wanted to direct wire your devices using an opti-pac, you'd have to convert them to non-usb devices, which would requre either swapping the optical encoder boards or modifying the existing boards (assuming that is possible).
This would definitely be a lot of work.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Ldsfunaz
« Reply #2 on: July 11, 2005, 04:12:58 pm »
awesome, so i would just need a USB hub then to get them both workign together?
Ldsfunaz
« Reply #3 on: July 12, 2005, 06:46:47 pm »
umm Im not a big bumper but i feel this is a simple enogh question..  a usb hub will work then?
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #4 on: July 12, 2005, 06:50:00 pm »
You could buy a USB card with enough ports in it and then plug the spinner and ball directly into your PC. That may be a cheaper solution too.
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #5 on: July 12, 2005, 07:14:19 pm »
I did something similar to what clanggedin is suggesting.  My trackball is P/S2.  So was my spinner.  I got a usb converted and plugged it into my usb port.  Yes, one will move the other, but the odds of that happening too regularly are extremely slim.
Stingray
« Reply #6 on: July 13, 2005, 11:28:43 am »
Yes
-S
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #7 on: July 13, 2005, 12:00:48 pm »
Did oyu get the happ usb thing already?  If not save yourself some money and either get a bprehacked mouse from oscarcontrols or hack your own.
WAAAIIIITTTT.  Doesn't the tornado come with a USB interface?
krick
« Reply #8 on: July 13, 2005, 12:08:28 pm »
Hantarex Polo 15KHz
AlanS17
    • AlanS17
« Reply #9 on: July 13, 2005, 12:45:35 pm »
I thought Oscar Controls was closed for the time being.
