Author Topic: IPAC 4 and Admin Buttons  (Read 1968 times)
Phunk96
  • Last login:August 25, 2005, 09:06:27 pm
« on: July 07, 2005, 09:30:12 pm »
Hello!
First post and BYOAC Newbie but taking on the adventure!
My question is what about using this to setup admin buttons with the IPAC4:
http://www.groovygamegear.com/cgi/surfshop/shop.cgi?ud=MkhKMUo3U0VVWSUlJSUlJTExMjA3ODQ1NzYA&storeid=1&cols=1&categories=0035&&c=detail.htm&itemid=KSHZADAP
I know that it is SUPPOSED to be for the keywiz, but why wouldn't it work to press the p1 button and then the button for the enter, pause, esc, etc...
« Last Edit: July 07, 2005, 10:12:04 pm by Phunk96 »
mark shaker
  • Last login:March 04, 2022, 09:27:06 pm
  • Oh Crikey!
    • Mark's Basement Arcade
Re: IPAC 4 and Admin Buttons
« Reply #1 on: July 08, 2005, 06:34:43 am »
If I get what you are asking: The I-PAC 4 has a built-in "shift" feature.  No additional cables are necessary.
Just use the included WinIPAC software to program the I-PAC. You can select your "shift" button, and assign a second keystroke to every other button.
   - Mark
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: July 08, 2005, 10:05:25 am »
Won't work because the I-PAC sends shift codes on key release, not key down like the KeyWiz.
You can do what you want with a resistor and capacitor (per button).
See http://www.ultimarc.com/extra_shift.html and the section labelled "I-PAC STEALTH MODE" on this page http://www.mameworld.net/tigerheli/encoder/shiftkeys.htm
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: July 08, 2005, 10:08:59 am »
Bigger question is why would you need it.
That circuit is designed for the KeyWiz so you can send a shifted input with a single button press.
This is useful if you are using all your 32 inputs and need additional shifted inputs for coin and start.
It would make sense for an I-PAC/2.
Do you really have 56 action inputs and not enough remaining inputs for admin functions that you need one-press shifted admin buttons on your CP?
Phunk96
« Reply #4 on: July 08, 2005, 10:29:34 am »
Thank you for the information.
It isn't that I have that many buttons, but I was just thinking of future expansion to 8 buttons per player instead of just 6.  To which I could leave those inputs open.
I think I am just going to use some of the extra locations for the admin buttons.  I do appreciate your help though.
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: July 08, 2005, 10:47:03 am »
You do realize that for arcade games you don't even need six, D&D are the only games that use 4 buttons for Players 3 and 4.  All others use 3 or less.
For console emulation (Nintendo 64, Dreamcast), you may well want 8 buttons per player, but IMHO, you would be better adding concealed front USB ports and plugging in gamepads for these games.
Phunk96
« Reply #6 on: July 08, 2005, 11:06:58 am »
Yeah I know that most arcade games don't use that many buttons.
I was just thinking of possibly doing some console emulation possibly in the future.
