Author Topic: CP wiring  (Read 1637 times)
toyfiend2004
  • Last login:May 12, 2007, 09:07:04 pm
  • Like... where do you put the quarters, dude?
CP wiring
« on: July 06, 2005, 01:34:12 pm »
has anyone wired a CP up with just Cat5 Cable?
conseit68
  • Will sell anything that isn't nailed down...
  • Last login:February 12, 2020, 10:52:27 pm
  • Back to the Future Cab...In Progress
Re: CP wiring
« Reply #1 on: July 06, 2005, 01:39:08 pm »
i just did...works very well :)
toyfiend2004
Re: CP wiring
« Reply #2 on: July 06, 2005, 01:48:23 pm »
now if my thinking is correct, it makes things neater, right?  which encoder did you use?  here are my goals...
1) Ipac4
2) 4 players (duh)
3) 8 buttons per (not including start and coin button)
this should simplify things.
conseit68
Re: CP wiring
« Reply #3 on: July 06, 2005, 01:53:30 pm »
yes it should work out very well. neatness was very clean. i ended up using a 25 pair cat5 cable that i have access to through work so i had more than enough color coded wires in a neat little bunch :)
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: CP wiring
« Reply #4 on: July 06, 2005, 01:54:10 pm »
toyfiend2004
Re: CP wiring
« Reply #5 on: July 06, 2005, 02:00:18 pm »
nope.  8 buttons.  I am making it ePSXe playable as well and there are 8 main buttons for playstation, snes has 6 buttons, etc...  then there are also the four directions on the Joystick as well... but i was not counting them originally.  just the 8 buttons
conseit68
Re: CP wiring
« Reply #6 on: July 06, 2005, 02:38:05 pm »
8 buttons each player
4 directions each player
that only leaves 8 for admin., coin, start, mouse, etc.
you might have a better chance going with a keywiz and a gp-wiz. just a thought...
toyfiend2004
Re: CP wiring
« Reply #7 on: July 06, 2005, 03:04:34 pm »
the Ipac 4 has a coin and start already & I will either utilize the shift feture for the other admins, or I will also use the Ipac2  and as for the mouse, i plan on optipac-ing the mouse/trackball.
thetered
  • Last login:April 12, 2011, 02:29:57 am
  • Dirty!
Re: CP wiring
« Reply #8 on: July 06, 2005, 04:51:45 pm »
I used stranded cat 5 cableing to give it better durability over single stranded, although I used single stranded to ground everything.  So far it is holding well.
