Author Topic: Do touching wires matter? (JAMMA)  (Read 1750 times)
ninjazx7
  • Last login:March 22, 2006, 11:33:02 pm
« on: December 16, 2002, 04:20:50 pm »
Hi guys, I was wondering if touching wires matter in a JAMMA cabinet. I am going to try any power everything up tonight, and I know that there are some wires that I won't connect just to test all of my stuff. Does it matter if these wires are touching? Will it short something out or damage the PCB?
Thanks,
Matt
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Do touching wires matter? (JAMMA)
« Reply #1 on: December 16, 2002, 04:30:14 pm »
Thanks,
Matt
are you asking if loose wires (not connected to anything) that have copper showing is a moderate risk for a short that could toast your PCB? Well yeah...  possibly.  You could  temporarily shlop some electrical tape over the exposed ends just in case, before you power it up and bend the wires away from eachother/other bad places to touch...
Just cause you have loose wires doesn't automatically mean you'll toast your game/monitor/etc... but you're increasing your risk of accidently do something stupid/costly with a bump here or there while you're reaching in there or whatever...
good luck...
rampy
PS wire nuts also work nice but are probably overkill for a test run...
ninjazx7
« Reply #2 on: December 16, 2002, 04:36:55 pm »
 ::) Duh....electrical tape.....God, it's been a long day at work. I didn't even think about doing that. Thanks alot.
Matt
