Author Topic: Slikstik Classic CP & Existing Cabinets  (Read 1184 times)
arcadegamenut
  • Last login:July 16, 2010, 01:48:45 pm
« on: June 21, 2005, 12:12:06 pm »
Slikstik Classic Control Panel -
What existing cabinets (if any) do not support this control panel?
What existing cabinets (if any) support this control panel with no modifications?
What modifications (if any) are required for other cabinets?
Tiger-Heli
    • Tiger-Heli
Re: Slikstik Classic CP & Existing Cabinets
« Reply #1 on: June 21, 2005, 01:03:19 pm »
Looks like it needs a 35" wide area.  My guesses would be their cabinet supports it and all others need modifications.
arcadegamenut
« Reply #2 on: June 22, 2005, 01:01:13 pm »
I received an e-mail from SlikStik. According to them, some cabinets, for example, a tempest cabinet, would require extensive modifications.
They recommended going with a cabinet such as the MK II cabinet as it already has a shelf and would require the least about of modding.
pointdablame
  • Last login:July 25, 2025, 11:13:52 pm
« Reply #3 on: June 22, 2005, 01:03:25 pm »
A cabinet with a shelf is a must, otherwise you'll be chopping up the machine.
Mortal Kombat could possibly work with litte modification, as well as Konami cabs like Xmen or Simpsons.
One thing to note though, some cabs with shelves will look pretty ugly with such a wide CP.  If you want to put that on an original cab, I'd recommend one that already had a wide CP, such as the Konami cabs I mentioned.
first off your and idiot
arcadegamenut
« Reply #4 on: June 22, 2005, 01:09:32 pm »
Yeah...the more I keep looking at it and thinking about it, the more I'm tempted to just fold and get their cabinet/control panel combo. That would solve a lot of my problems (no truck/truck rental, no tools/tool rental, etc).
If I make the decision soon enough and were to order it, I could time it so that I'd be on vacation right about the time it would be delivered. :)
Katana Man
  • Last login:September 22, 2024, 12:10:44 pm
« Reply #5 on: June 22, 2005, 01:51:11 pm »
SlikStik control panels will work on pretty much any cabinet that has a 90 degree cutout.
Check out my conversion project for details:
« Last Edit: June 22, 2005, 02:39:31 pm by Katana Man »
