Author Topic: IPAQ4 "Player 1 Up" Problem  (Read 2081 times)
Sloan
  • Last login:July 08, 2008, 09:37:00 am
« on: June 15, 2005, 11:09:13 pm »
Can anyone list reasons why my IPAQ4 would be reporting that both the 1st player UP and DOWN are being triggered at the same time.
Here's things I've checked:
The Player 1 up and down each only have one wire running to their terminals. Both UP and DOWN are securely wired and grounded. There arent any loose fragments of wire that would be causing both wires to trigger one another.
WHen I was out of ideas I figured I could try to hook up the joystick to the player 3 terminals to see if it was a bad terminal. If I attempt to hook up player 1 up and down wires to player 3 up and down, they for some reason also trigger the second players "3" and "6"th buttons.
I also made sure that in the IPAQ Configuraton Utility that I'm using the default settings and that no buttons are double-mapped.
I can't figure out these oddities. Having my player one joystick work properly is the last thing I need to do before I can enjoy my new cabinet. I greatly appreiate any help you guys can give.  :)
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: IPAQ4 "Player 1 Up" Problem
« Reply #1 on: June 15, 2005, 11:16:55 pm »
wires right?
Double and tripple check them..
Oddly i had the same issue.. was a poor wire job..
Sloan
« Reply #2 on: June 15, 2005, 11:21:14 pm »
yeah wires are fine.. pretty cut and dry direct connection... the only wire related issue i can think of is that maybe if some fine loose strand of wire made its way deep inside the screw down terminal.. but i believe those terminals are actually sectioned off from one another so this doesnt happen...
btw, love your sig. happy noodle boy rules  ;D
Bones
  • [Moderator]
« Reply #3 on: June 15, 2005, 11:24:17 pm »
I would start isolating things one at a time and check as you go. It has to be something simple.
cdbrown
  • Bowowow
« Reply #4 on: June 16, 2005, 12:04:31 am »
How are you testing the these inputs or where is it reporting these errors?  In the config utility itself or elsewhere.
When you push up on the stick does it report both up and down, what happens when pushing down?
Have you tried removing the up microswitch and actuating it with your finger - what are the results?  Do the same for the down microswitch.
Make sure that the wires are always to the NO on the microswitch.
Sloan
« Reply #5 on: June 16, 2005, 12:44:52 am »
* I'm testing this in the supplied programming utility that comes with the IPAQ (windows build)
* When i push up it reports both up and down & when i push down it reports both up and down
* I'll go try the manual actuating with my finger now
* All wires are connected to NO
thanks guys for the suggestions... i owe you each a beer (or a coke dependant upon age)  ;)
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: June 16, 2005, 06:16:27 am »
What joystick?
I believe the T-Stick Plus uses the 1st and third terminals for NO and Ground, rather than the 2nd and third - although just wiring it to NC shouldn't cause the reported behavior.
Again, if possible try with just a switch or button connected to 1Up, and/or try with a different joystick.
Weird.
Sloan
« Reply #7 on: June 16, 2005, 02:19:02 pm »
Just wanted to let you guys know I fixed the problem... simply took all the connections out and reseted everything to defaults on the IPAQ Windows interface. At this point things were still not working but when I hit the program button, things worked as they should. I guess there was some discrepancy between the joystick, ipaq and interface software. I probably had confused both it and myself when programming the board incorrectly the first time.
 Thanks for the support guys!  ;D
